20 Most Recent Pride Victory 4 Wheel Mid-Size Electric Scooter Questions & Answers
It's usually a white button down at floor level between your heels
Pride Victory 4... | Answered on Aug 02, 2016
There are several
the right hand tiller leaver is for adjusting the tiller pitch
the left hand tiller leaver is the hand brake - keep that lubricated and squirt a bit of wd40 down the inside of the brake cable if you can.
The leaver on the right of the seat post is the motor brake freewheel leaver, the seat leavers are for swivel, back pitch.
Pride Victory 4... | Answered on Jun 03, 2016
Change the XLR PLUG ( three pin male or chassais female are easily found on the internet. Always plug the carger to the mains supply last and remove the mains end plug first when unplugging.
check for shorted wiring inside the XLR plug
Pride Victory 4... | Answered on Jun 02, 2016
hi Mariano, please remember it does not have to be the exact brake as long as the watt and fittings are the same it will work..
Regards...
Pride Victory 4... | Answered on Mar 03, 2016
hi sadly you won't however i can help , what's the problem ?
Regards
Rob
www.gewizrepairs.co.uk
Pride Victory 4... | Answered on Jul 10, 2015
Hi , 7 bleeps is the throttle pot error , either a calibration problem or a faulty pot, i can help you , please contact me
Regards
Rob
hi, they cover a span of five years, what do you need to know ? or require , the later ones did not have a inbuilt charger...
Regards
gewizrepairs.co.uk
Pride Victory 4... | Answered on Dec 22, 2014
Try spinlife.com or call them at 1-800-850-0335. Maybe Customer support or manuals, technical assistance.
Pride Victory 4... | Answered on Jul 09, 2014
hi , i suggest you call Pride and give them the serial number ...
What's your location and i get you a phone number...
Regards
Rob.
www.facebook.com/gewizrepairs
Pride Victory 4... | Answered on May 24, 2014
If it is an SC1700, the year is 2008. I will verify for sure if I can find located on the scooter somewhere.
Pride Victory 4... | Answered on Apr 07, 2014
Neil is right, the serial number is on the seat support. From that the year can be determined. It's mostly moot, as Pride only has a 1 year warranty, and after that, it Parts and Labor. Why are you asking?
Pride Victory 4... | Answered on Apr 02, 2014
Hi. MostPride scooters have the serial number on the front of the seat support colomn. You will have to remove the seat and the cover over the batteries to see it. Good luck. Neil.
Pride Victory 4... | Answered on Apr 01, 2014
If the scooter in question is a Pride Victory with on board charger ? ( you plug a mains lead into it ?) now what happens with this particular scooter as the charger starts to fail, it's not charging the battery correctly, if you have access to a multimeter DC setting , check the voltage from one of terminal of the battery to the other terminal of the opposite battery, now it should read at least 18 volts , 0 volts then you need to change from one terminal to the other and same for the other battery ,, now if it below 24v that's the problem because as soon as you put it under load the voltage drops to under the minimum working voltage for the controller , hope that makes sense so other-words you need to replace the on board charger , contact me and I show you a way to do this cheaply...
Regards
www.gewizrepairs.co.uk?fixya
Pride Victory 4... | Answered on Nov 17, 2013
Hi, Sounds like a loose connection from the controller to the motor, now check the wire leading to the motor, two for the motor and two for the brake, the brake wires being the thinnest....
Regards
Pride Victory 4... | Answered on Nov 16, 2013
Pride Victory 4 Wheel Mid-Size Electric Scooter  Logo
48 questions posted
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Health & Beauty
Most Popular Question
find model or year victory scooter
  • Health & Beauty
