How to charge
The Jazzy Select 6 requires an off-board charger. Plug the charger into a grounded outlet; preferably one that doesn't have other large loads on the circuit like refrigerator, freezer, microwave, etc. The male 3-prong XLR connector coming off the other end of the charger plugs into a female XLR connector which is on the joystick control's bottom-rear. Charge it overnight after each days use, and at least once each month overnight. You should get 2-4 hours of use from the chair at top speed with a 200 pound driver, depending on terrain and climate. If it isn't holding a charge, you will probably need two new U-1 type gel sealed batteries that run about $120.00 or so each. Make sure you test the old batteries first at a knowledgeable battery shop. These are deep cycle batteries and require a special testing. If the batteries are good, then your charger isn't charging. Search EBay or other online sites for a wheelchair charger in the 4-6 amp range. They can be found for about $45.00 or so. Pride will charge you a lot more.
my motorised wheelchair when i charge it it charges but when i turn it on it wont turn on what may be the problem?
