Ovens Logo
Posted on Apr 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool electric range RF361 bxdn 0. error codes? PF?
Re: whirlpool electric range RF361. what do the error codes mean? I cannot find a manual online. Error codes in Bake mode are either PF or F3. Oven beeps until is unplugged. Replug and it will go for 1 minute before giving an error message again.
Thanks for help to find a manual and find a solution.
Jon
Anonymous
Level 2:
  • Expert 53 Answers
  • Posted on Apr 02, 2008
Anonymous
Expert
Level 2:
Answers
53
Questions
0
Helped
87556
Points
112
Hi Jon
look on the back of the unit, there should be an envelope that has a paper in it, that paper should tell you what the code means.
1helpful
What does E2 -F 1- mean?
A E1-F1 or E1-F2 is a faulty touchpad.
FixYourBoard.com has replacements about for NLA ovens.
They come with a two year warranty.
Reach out to us at 512-355-1108 or [email protected]
tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
2answers
What does the message PF mean?
PF = Power Fail. Possibly damaged control board.
1helpful
Code F1E2 on whirlpool electric range mean
This is not a good code and usually means the electronic control will need replacing. Try disconnecting the power for a couple minutes and if the error comes back, the control is bad and will need replacing.
Recieved a PF code and my oven will not work. Is there anything I can do?
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Pf code
heatman101
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
