Pioneer SD-P50A5-K 50" Rear Projection Television Logo
Posted on May 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Has problems turning on
It has problems turning on... wondering how to fix it and how much it would cost to fix it. Sounds like the power supply is malfunctioning
electronic & computer repair& servicre
Level 3:
  • Pioneer Master 12,061 Answers
  • Posted on May 11, 2010
Pioneer Master
Level 3:
Answers
12061
Questions
0
Helped
4008259
Points
36390
Www.scribd.com/.../Pioneer-Pro1410hdPdp614mx424mx-Training-Manual -
www.scribd.com/.../Philips-DPTV400-TV-Projection-Training-Manual The manuals above are service and training manuals for your type of TV, these give troubleshooting procedures to help troubleshoot.
With this symptom, it is impossible to tell what the exact "Cause" of this symptom is. The symptom do not tell us what is wrong, sometimes it may indicate the "Area" in your case it is the X board. BUT thats NOT where the "Fault is" thats just the part that is affected. These days unlike the "Old" analogue days it just isn't realistically possible to fix anything but the most basic of problems with todays sophisticated units. This is quite apart from the Safety aspect, any unit that can cause a firs or have an explosion, or both, is NOT to be treated lightly, and and the repairer, of the unit is legally responsible, another thing to think about. Also, one must have tools, a Multimeter, a soldering iron, a deslodering iron, an oscilloscope, a signal tracer, tools, and most important of all, a Service Manual, without which, there is no way to even begin to understand and fix it, and more importantly Program it, AFTER it has been fixed. As these days a TV, is a PC, a Tuner, and an HDTV Monitor, and more, all in one. in the "old" days TV"s were more, rudimentary, and built to last for 20 years, and a "Parts" supply was set aside. They usually used to fail for only a few reasons, and they while still difficult, were less difficult to repair. Electrical knowledge was transferable, and they could be and would respond to, This-is-the-symptom-This-us-the-Fix, But that no longer applies, as now, it can be a Fault on I squared Bus, or "Sensor" failure, or it simple may have "Crashed" just like a PC, It could be a Diode go bad, and that will stop the whole thing. You see, in the day, the sets were Very "Fault Tolerant" because they were Analouge, and a faulty, component, or more sometimes, the set would always diplay something usually, and when they didn't it was one of anly a few things, sure there are always the horrid ones, and there are pleanty of those, but all in all it was quite easy. But with Digital Electronics, it either goes, or it doesnt, there are usualy few half measures. I mean thats the definition of logic either going or not. So it can take very little to completely paralyse a set, and generally give the only sysmptom, it can, by not working, usually No picture, or the like. So you, see the list is endless almost for any given SYMPTOM, as that is what is being seen, not the cause, as I keep going on about. Also any fault, usually involves the Power Supply, it is either the cause, the cause of the damage, or it is damaged. or ALL of them. Then after you have done the electronic repairs, you then must program the set to work, and align, and set up in general, any one of those settings missed or done wrong, back to square one. So, it is nearly always my professional opinion that one should always get a "Quote" form the manufacturers recommended service center, I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else
2answers
Samsung LCD TV turns on and off on it's own
Based on the symptoms you described, it sounds like there may be an issue with either the power supply board or the main board of your Samsung LCD TV. The fact that the TV keeps turning on and off repeatedly on its own, and now it won't start up at all, suggests that there may be a problem with one of these components.
When you unplug the cord connecting the power supply board to the main board, and the TV backlights stay on without turning off, it indicates that the power supply board is working properly. However, when connected to the main board, the backlight turns on and off, which suggests that the issue is with the main board.
It's possible that the main board is malfunctioning and not providing the correct signals to the power supply board, which is causing the backlight to turn on and off. Replacing the power supply board with a new one and still experiencing the same issue, confirms that the problem is not with the power supply board.
It's important to diagnose the problem correctly and not just replace parts without properly testing them, as this can lead to wasted time and money. A proper diagnosis can be made by a technician with a scanner that can read the codes and check the signals of the main board and power supply board.
It's also a good idea to check all cables, connectors, and other electronic parts of the TV, as any damaged or loose parts can cause the problem as well.
It's recommended to check the TV's warranty status and the manufacturer's instructions to ensure that the repair or replacement will not void the warranty. If the TV is out of warranty, it might be more cost-effective to consider purchasing a new TV, as repairing an older model might not be cost-effective.
Led will not show.comes on for a second then blank
James, sounds like a power supply issue.links below to shed some light on your issue.
to show your appreciation press the helpful button and follow me on fixya for more tips and info.
How to Fix LCD Monitor Power Problem
MOST COMMON REPAIR FOR LCD NO POWER
Fix Malfunctioning LCD Power Supply
How To Test Computer Monitor That Won Display Or Is Not Working
1helpful
KDL-40XBR4 bought 1/08. Turns on for 30 seconds with screen staying dark. Then it goes off automatically with the stand-by light blinking 5 times repeatedly. Took it to the shop and he said the LCD panel...
KDL- Bravia blink codes (Australian):
2 times-Main power supply voltage error (12V, etc)
3 times-Malfunction of 3.3V line
4 times-Malfunction of 5V line
(Voltage Supply to FE, etc)
5 times-Malfunction of power supply for screen
6 times-Malfunction of inverter or overcurrent, etc
7 times-Abnormal temperature inside unit
8 times-Audio circuit error (amplifier, etc.)
9 times-Fan malfunction
10 times- Digital FE circuit error
11 times-Malfunction of Trident IC or around IC
12 times-BH board error
13 times -Malfunction of balancer
If this is correct the 5 blinks is the power supply having problems, I would much rather change the PS than replace the screen. Also if screen is determine bad, look for class action lawsuit on Sony for defective screen, i am told they know all about this.
3answers
Hi iv got an nec 50 inch plasma tv model number pxt-50xd3 and i was told there is a power supply problem i was wondering if this is common and approximately how much will it cost me to fix?
Hi There I also have a nec 50inch plasma pxt-50xd3 its now not working. I have taking it to the repair shop who told me it was the power supply and it would cost me $550 to fix it.
Trying to turn xbox on and getting blinking red ring around power button
This problem is often called the Red ring of Death.
It's actually very common and is caused by a hardware malfunction that causes the system to overheat.
There are 2 ways to fix this problem: 1) Send it to Microsoft (if your warranty is expired it will cost $110)
2) Fix it at home by taking the system apart and repairing the malfunction. This can be daunting, but is actually easier than it sounds. I recommend having a look at these 2 sites:
http://threeredlightsonxbox360.com
http://www.squidoo.com/xbox360-red-ring-of-death-fix
3answers
Samsung hdtv, purple pixels and trouble turning on
probably the power supply is going out.common problem.
Problems charging
yes u can buy new jack and resoilder it in buy part off ebay jack u need for your model ok its tuff job to have it doen cost a 100 or more
Power supply problem
mine did this and it was the power supply like 140 bucks from the best buy parts search
Top Pioneer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
