Its an 8gb.i had it plugged into the computer it was off and i turned off the computer.then i grabbed it and there is a black screen that says Connected Eject before disconnecting. And the screen is black and i tried turning it on and off but nothing will happeni put it back into the computerand i put it on the ihome and nothing is happening please help!
If its a windows system, power it on and when bios screen appear, press F8 couple of times, this will take you to a list of options, select "Last good known configuration" and press enter. It will restart your system. don't put that flash drive again as it seems that it has viruses.
You did not turn it off completely. Press and hold the power button for more than 4 seconds or unplug the power cord. Then try again. If a problem persists, write here again.
SOURCE: its an 8gb.i had it plugged into the comeputer it
just remove the any usb pen drive which is connected to the cpu and try to switch it on .if there is no display remove the ram and try to fix it again.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
