Samsung HTC550 Theater System Logo
Anonymous Posted on May 09, 2010
Samsung LED UE46B7020 tv wont play sound through my HT-C5500
I cant get my samsung UE46B7020 LED TV to play its sound through my samsung HT-C5500 Blu-Ray player,the surround sound works fine with the player but when i turn to tv nothin just tv sound,they are connected together via HDMI cable and a digital optical audio cable but neither one will get my tv's sound through?? any help or suggestions are much appreciated
  • Anonymous Mar 22, 2014
    How do I hook up my RCA RTD3131 E Dolby digital surround sound to my Samsung Led tv?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2356
Points
13
I know this is going to sound stupid but i couldn't get mine to work either after following every instruction to the T. I then rechecked my optical digital connections again and found that I neglected to remove one on the rubber protective endings. I took it off and plugged the end back into my TV and BINGO! THEATER SOUND from my tv!
The Ticket
Anonymous
Level 1:
New Friend:
  • Posted on Jun 30, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2356
Points
5
Press the top right hand button on the remote for the ht-c5500 untill its display reads "D.IN" (Digital Input)
How do I get sound to a 32" LED SINOTEC TV to a SAMSUNG Digital Home Entertainment System HT-E350K
Check the audio menu to make sure the surround sound is on. Check to make sure the audio out cables are connected properly to the HT-E350K and the Samsung.
Samsung ht-c5500 internet tv not working
Hello!
I'm adding a link to the "troubleshooting" part of the manual. Hopefully, it will help! Other information Samsung HT C5500 63 68
Why wont my ht-e3550 play tv sounds
I have the exact same problem - I have connected the RCA cables but it's just not working....this is very frustrating. Anyone who has a solution - pls contribute! Regards, Justin
I can't set this on aux to get sound on my computer how do I do this it keeps setting to arc
Samsung HT- C5500 , they're connected by hdmi and audio(red and white) the speakers work when i watch a movie but not when i try to use them for watching tv, why wont it work?
we provide career option in Thailand like ccnp certification
and hardware and networking
I have a new samsung 40" led tv and i have
The specs say that it has an optical audio in on your home theater system. So the easiest way to hook up is to connect the optical audio out of your tv to the optical audio in of your home theater system and walla! What ever play on the tv will play on the home-theater system. You are looking for a Toslink optical audio cable
http://cgi.ebay.com/6-OPTICAL-FIBER-OPTIC-TOSLINK-DIGITAL-AUDIO-CABLE-6-FT-/370402436177
1helpful
Can not get my Samsung TV to recognize the ht system. I am able to get the sound out of the ht system and the video on the tv when i play dvds but the sound will not transfer from the tv to the ht system...
The way mine is hooked up is like this: Ps3, DirecTV box all plugged to my samsung TV and then only thing I have plugged into the Ht box is the hdmi out to TV and an Optical Cable from Tv to HT box. All audio is going to Tv then to HT box and plays all through hometheater box when it is on. Try the optical cable
1helpful
Cant get led tv to play sound through surround sound on blu ray
you have to have a connect going back into the player, the hdmi is only one way there should be and analog the red and white
or
an digital optical out from the tv
2helpful
Hi, Ive tried to set up my samsung blue ray
It seems as though the HT works fine, so to get the TV itself to play through the HT setup, take the audio out from the TV and hook it up to a separate channel on the HT receiver. Turn on TV and receiver and put the receiver on the respective channel of the receiver. I hope this helps.
Samsung HT-Q100 - Changed Battery on TV remote control
Just try to clean your remote,this the common problem of dirty contacts of remote it plays a certain unit but to the other won't play.Just open it take a toothbrush with an alcohol brush the remote control board,and dry it for 1minute and close it back then check if working..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
