20 Most Recent
Samsung HTC550 Theater System Questions & Answers
I have a panasonic viera
1. The easiest solution would be to connect a stereo RCA (red and white) cable to the audio output on the back of your TV.
2. Then connect the other end to the input on your home theater system.
3. Change the home theater system to the correct input.
When i turn on my
PROT means that the AMP is protecting itself from damage due to bad or incorrect wiring or damaged and or incorrect speakers. Check your wiring and speakers.
If you find no problem then, DISCONNECT YOUR SYSTEM FROM THE POWER, disconnect your speaker wires...all of them, then reconnect the power ONLY, turn on the system and see if it still says PROT. If it does then your amp is damaged.
Fm antenna
hahahah that's low reception try to connect into tv antena much better reception.
