This sounds like a convergence problem.
In the customer menu with the Mitsubishi remote select convergence and then advanced. You should see a grid of lines yellow in color.
If red or blue lines appear and are skewed and out of place you have found your problem.
I have step by step start to finish instructions for this type of repair in MOST OF THESE MODELS.
Let me know if it looks anything at all like the attached photos.
SD TECH
Hi
It's a good bet that the convergence chip is failing. The chip itself sells for $29. to $50. Replacing the chip is not greatly difficult but insuring that that is the exact problem is. With a good scope you can walk right through the circuitry on this set. I would recommend a reputable repair person. Note: anyone who can give you and estimate without going through the set and/or is willing to do the work in your home is worth bypassing quickly. Good luck
