20 Most Recent Mitsubishi WS-65807 65" Rear Projection Television Questions & Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mitsubishi... | Answered on Nov 01, 2017
Short answer: No.
The board and install will cost you more than an LCD/LED flat screen TV.
Sorry for the bad news, but you will save space and electricity with the new TV.
Next problem: Trashing the projection TV.
Mitsubishi... | Answered on Oct 25, 2017
do the self check if it comes on for a moment and then the power light goes off.
On the front of the set hold both the MENU and INPUT(also called DEVICE) together for at least five seconds and then release both buttons.
The power light will blink an error code--for example 2 blinks a pause and 2 blinks--it will repeat it several times. 2,2 is the most common error code for this set.
Let me know what you find and I will tell you what it means--it is designed to give a quick idea of what is wrong with the set.
if this helped you rate this solution as I do this here for free.
SD TECH
Mitsubishi... | Answered on Aug 09, 2017
I would just replace the TV.
Mitsubishi... | Answered on Jun 24, 2017
YOU may have two problems, 3 d picture or letters suggests convergence problem, Tell me more, all inputs have no function?
The more you tell me the better I can help.
I am expert with these sets and know them well.
SD TECH
Mitsubishi... | Answered on Sep 13, 2016
It sounds like one of the three color guns has failed and based on the fact that you have red and green that would leave the blue gun as the culprit.
Mitsubishi... | Answered on Feb 16, 2016
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
SD TECH
Mitsubishi... | Answered on Nov 30, 2013
Mitsubishi WS-65807 65" Rear Projection Television Logo
271 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
add hdmi port mitsubishi ws 65807
  • Televison & Video
