It means that the driver for the audio card is not yet installed or is malfunctioning. Reinstall the audio driver for your laptop by inserting the cd that came with it and then restart the laptop after installation.
hi! I think u need to install drivers in your PCI internet/LAN Card or built-in LAN
Please check the brand of Motherboard if it is built-in or the PCI Card Brand. and browse it in the net with another PC with the NET connection, to the manufacturer websites. and search it with corresponding model of the motherboard or the PCI Card. and download the Driver's and save to USB
and paste it to ur PC and install it.
if this tips is helpful. please rate it. thank you.
Disconnect all power to your PC.
Open up the cover your PC (CPU) and find spare connection on *********** ( beside your VGA / video card). If you see a spare, you can install your card there. If you found cover with screw, remove it accordingly. Place your sound card on female adapter securely.Check if there is output audio wires from your cd rom and connect to your sound card. Close the PC cover. Power on your PC. If you have external active speaker, connect it out to sound card audio output.
Now you supposed to can play your PC with sound card.
The instructions are on the CD that should have come with your adapter. Few companies supply anything in print now; the manual is usually in a pdf file.
Put the CD in and start the installation program. It will probably start automatically, in fact. The program will guide you through whatever steps you need to follow. Usually it's just a matter of installing the required drivers, maybe restarting your system, then plugging in the adapter.
Once the adapter is installed, you run the connection software, pick your network from the list it will show you, enter any security passphrase your network requires, and you're wirelessly connected. You may also need to configure wireless operation on your router if that hasn't been done yet.
The main problem is in the RAM or MEMORY CARD, just detach it and place it back or on another slot beside it.... if this dont work, buy a new memory card. but this usually works
Found this on the net: http://www.brad-x.com/2007/10/27/howto-leopard-install-with-giga-designs-g4-upgrade/
Those upgrade cards always have given me a problem with migrating to Leopard. If you can upgrade to a used G5 or even Intel basd mac you might be more happier with less hassle.
download (PCwizard) install it and run it checks your computer for all drivers needed and lists them Note name and number of drivers required and do a search on net for them EG cmedia 2341 drivers substitute your driver name and numb
IT seems no problem with your specification, but only one thing less in this criteria. What inch does your monitor? This must be match with the specification of your VGA Card, The more resolution you can get the best performance of this VGA card you can achieve, try to higher the resolution of your monitor , don't only use 1024 x 768 , but try another higher resolution. The VGA itself cannot reduce the system perfomance, because your vga card has GPU (This VGA card has his own processor and memory) just like mini computer inside your main computer.Hope this things can solve your problem, don't forget to vote
if u r going to connect ur pc through wired no need to install any thing>run a cable from pc to the ether net jack on the cisco router and it will start working>u need to use rj-45 cables>
if u r going to use pc's through wire less then u need to login to ur router and change the SSID name as ur wish and enable the ssid broadcast>and change the channel 1 or 11>and save that >and restart the wire less pc's>and in the pc right side down corner u can see wire less i-con>click that and click on view avaliable net works>and search for the SSID that u changed in the router screen and click on connect rate me solved if its help thx
