My Lenovo Y410 laptop is getting hot and shutdown automatically sometimes.somedays this problem is occuring very frequently.
Please let me know what might be the problem.
Thank you.
Saroj.
Clean cpu fan if wont work change it
Its normal your computer is automatically shutdown because the system hardware cannot bear the heat anymore that was produce in computer hardware. hardware is degrade when time goes by. so the basic solutions is to provide your laptop a cooling pad.
When systems power off suddenly, always suspect - the power first. I would then look at heat and physical connections next as culprits. Memory errors almost always show up as blue screens.
I say try a new power supply and see what it does. Its not a lot of money either way.
Run CPUID Hardware Monitor and watch your temps. You will have to turn logging on or you will lose the data in a crash.
Make sure your CPU heatsink is still connected properly. Things have a way of working loose.
PLS REPLY OR COMMENT. THANKS
