I have my Hitachi setup to Direct TV, and I just switched to a standard Antenna temporarily and was able to perform the channel scan. But when it was complete I was unable to change the cannel. It is stuck on 0.
When I set it all up I programmed the Direct TV remote to control my TV. Since then I have lost my remote. Is there a reason why my TV will not change channels?
SOURCE: Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
SOURCE: Can't change channels
I had exactly the same problem. I finally found the power button on the underside of the TV. It is well hidden and to find it, you need to run your fingers underneath the panel. Turn it off for a minute or so and turn it back on and then turn on the switch on the panel on the upper right side where the channel and volume buttons are. It works.
SOURCE: Hitatchi 42HDF52 only receives channel 5 and 6 on analog RF input
If you have tried autoprogramming and have found nothing it may be a bad tuner. Is your VCR is hooked up via coax or into a video input? If it is hooked up via video and is working but the coax connection direct isnt it will be a bad TV tuner. Easiest cheapest fix is to use you VCR to change channels or get a Digital Cable Terminal from you cable provider and hook it into video or compnent.
SOURCE: I have Hitachi 42PD9500 flat screen TV. The TV
RE TUNE UR CHANEL-LS IN AUTO TUNING.......U WILL FIND THE INSTRUCTION UNDER THE MENU ON UR REMOTE CONTROL........JUST FOLLOW THE PROMT
SOURCE: I am running a Sky + HD box through my television
Hi, without a manual to hand, i don't know, but my Panasonic had the same problem, but I found somewhere in the settings, I could change it, it has something to do with AV and Digital TV and hdmi setup, give it a check.
I hope this helps to some degree, but give us a shout if you require more help.
Regards - Anthony
