Programming on the nortel system is done on M 7310, M 7324, or T 7316 sets only.hopfully the receptionist station has one of the larger sets.
Testimonial: "With clarification that I gave on steps I took and what were results within three questions figured out the problem and solved it. Thank you very muc"
If you tried the Feature **8463 (TIME) and that didn't work, I can only say that I'd try unplugging it from the phone cord for a couple of minutes and then replugging it. That should reset the system. If that doesn't work and you still can't change the time via Feature *8463, I'd think it was a hardware problem, and contact your seller to see if you still have a warranty on it.
It doesnt do anything after that just stays same on screen then feature times out
It does nothing just sits there and feature will time itself out.
Well tried the unplug, day is correct time is off, plus now i get access denied
What does it say on the screen when you enter feature ** 23646?
