Samsung HL-S5679W 56" HDTV Logo
Posted on Apr 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 56' that wont show picture
I have a 56" samsung rear projection tv that won't turn on. the red standby light is lit and when i push the power i hear two clicks and the green timer light flashes quickly then the green led stays lit for a couple of seconds then the it flashes 5 times between the red standby and green timer on the time both the green timer and green led lite at the same time then 6 more flashes between the red standbye and green timer and then the red standbye stays lit and i hear a final click. It did this the other day and i unplugged it for a minute and got it to work but that is not working this time. Any help would be appreciated. thanks in advance. Cash
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jul 12, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
3109
Points
12
Power board is bad.. I had the same issue.
Jose Garcia
Level 2:
Champion:
  • Expert 453 Answers
  • Posted on Apr 14, 2010
Jose Garcia
Expert
Level 2:
Champion:
Answers
453
Questions
0
Helped
92531
Points
112
U mat need a lamp replace ,
1 Related Answer
Anonymous
  • 1284 Answers
  • Posted on Nov 03, 2009
SOURCE: I have a 56
I suspect you probably have a bad LED assembly. It could be either the red, green or blue that is bad and give you the same symptom. The problem is locating parts for it as it looks like the light engine is no longer available. I would have a technician look at the TV to verify this and what parts are needed for repair.
1helpful
My tv won't turn on when the on button is pushed, but the power light blinks 5 times
5 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Heard a loup pop when I turned the tv on; the timer/lamp/standby/temp lights on the power on button are now flashing; when I pushed the power button again the lamp light on the power button flashes and...
Color Wheel - Pull out the Lamp using a flash light look right into where Lamp was you should see the color wheel turn TV on watch to see if wheel is turning,From what you have said Problem will be the Color Wheel. Encompass Parts Distribution has them 1-800-638-3328
I have a 56" samsung rear projection tv that won't turn on. the red standby light is lit and when i push the power i hear two clicks and the green timer light flashes quickly then the green led stays lit...
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
1helpful
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Picture is double lined of greens and reds
You have a convergence output IC failure. You my also need a few small associated parts as well. Expect to pay $350-450 to have this fixed.
michtech
5helpful
Samsung 52' TV Is showing red
MY SAMSUNG TV MODEL NUMBER LE32R87BD IS DISPLAYING A RED FLASHING LIGHT ON THE POWER BUTTON AT THE FRONT OF THE TV THERE IS NO PICTURE PLUS IT WONT TURN ON CAN ANYONE ASSIST ME WITH THIS PROBLEM
8helpful
Standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
2helpful
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
No Picture
I took mine out and sent it to PTS Corp. They fixed it and had it back to me in about a week. Cost about $115.
www.ptscorp.com
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
