Microsoft Xbox 360 Console Logo
Posted on Apr 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Okay i just got xbox live and hooked everything up. I turned it on and all it did was light up green in the middle (as usual) but it didn't show the 1st player sign. It made my controller like it wasn't synced so i synced it (didn't work). Alsoit doesn't show anyhting on the screen help me now!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Anonymous
Level 2:
New Friend:
  • Expert 111 Answers
  • Posted on Apr 13, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
111
Questions
0
Helped
31144
Points
342
Shut down your Xbox and take out the batteries of you controller. wait a minute or so. Then turn on you Xbox, put the batteries back and power on the controller. when it doesn't recognize it:
1 press the sync button on you Xbox
2 press the sync button on your controller
That will do the job
Pablo Gonzalez
Level 3:
  • Master 733 Answers
Pablo Gonzalez
Master
Level 3:
Answers
733
Questions
0
Helped
266273
Points
2189
Are you using HDMI input? Make sure you have it on the correct input as it will not start until it sees the the input from your tv. don't switch inputs real quick, give it some time and it should boot(about 3-5 seconds). Mine did the same thing with HDMI only.
1helpful
4answers
3 red lights and one green one in the middle HELP
Put the console off ..... wait 10 seconds and then try again
How do you setup xbox live with a wireless connection my router is upstairs but i want to play my xbox 360 downstairs
Okay, to connect to Xbox Live using Wireless Internet you will need this:
One Xbox Wireless connection unit, There are two types, the black and white versions. The black one is able to pick up the most diverse signals and has a higher potential for speed so I recommend that one.
You will also need, of course, a high speed internet source (modem) and a wireless router connected to the modem. When looking for wireless routers look for ones with marks claiming to be compatible with Xbox Live or a Windows OS. Those have been tested to work with Xbox.
Before trying to set up your Xbox Live, make sure your Router is set up with your computer, and set to be used as a wireless router. That's another tip all together but just follow your installation CD.
Okay so here we go!
First, Connect the wireless networking adapter to the back of your Xbox.
If you have a network cable plugged into your xbox, unplug it. Check to make sure the adapter's light is on.
Here's what the light's mean:
On the gray adapter:
No light: It's not getting enough power( try plugging it another USB slot)
Green light: It is connected to a wireless router, gateway or wireless access point.
Red light: It is not connected, and is ready for configuration.
Flashing red: There is a malfunction. (try again, if the problem persists return it for a replacement)
On the black adapter:
Green light: It is connected to a wireless router2_bing.gif, gateway or wireless access point.
Flashing green: The adapter is attempting to connect to a wireless router, gateway, or access point.
Now the CONFIGURATION, the reason most of you are reading this:
Turn your Xbox on and go to "My Xbox"
Go to "System Settings"
Go to "Network Settings"
Go to "Configure Network"
On the basic settings tab select "Wireless mode"
Select "Scan for Networks"
Select your Wireless source.
NOTE: If your Network isn't listed you will have to manually enter it.
To do this select "Specify unlisted network"
You will need to enter your SSID
Then choose which security you used to set it up on your Computer (ie: WPA, WEP...) Then enter your security code. If there is no code then select "no security"
Your adapter should have a green light now.
Now go back to "Network Settings" and select "Test Xbox Live2_bing.gif Connection"
If it works your good to go!
If not read visit: http://support.xbox.com/support/en/us/Solutions/wizardhost.aspx?wizardid=xlcsv1
Hope this tip helps :)
1helpful
Xbox live on netopia router
Okay so here we go!
Hope this tip helps :) Tell your friends and ratings are nice. Just kidding, I just hope I helped.
How can i get xbox live wirless working after buying the adapter. I have bought the xbox wirless adapter and i am having trouble getting wirless.
Okay so here we go!
Hope this tip helps :).
Need help connecting xbox live to the internet, have the wireless router but nothing is successful
Okay so here we go!
Now go back to "Network Settings" and select "Test Xbox Live Connection"
Having problems hucking up to xbox live
Okay so here we go!
4helpful
3answers
Turns on but no picture or sound and the machine sounds quiet?
I was having the same problem, and what seemed to fix mine was my hard drive. I keep my 360 on it's side and it [hard drive] was falling out a little. I pushed it back in and that seemed to do the trick. Also, when I fix my red rings, I just turn the console off, unhook EVERYTHING and leave it out for a minute. Then I hook everything back in (power cord, hdmi cable, ethernet cable, and hard drive) and it usually works out ok. I'm not saying that fixes everything, but, it has for me in the past.
6answers
how can i fix this ring of death it will not let me play the game
XBOX SHUTS OFF.
You could have a faulty power supply. Have you checked to make sure everything is hooked up properly? When you turn your xbox on have a look at the light on the power brick, its usually green when its working fine and orange when the xbox is turned off, if its red there could be a problem with it.
Hope this helps
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
