Probably the Bendix needs lube. This is the spiral that the pinion gear runs on.
Remove the starter and inspect to insure the pinion gear is in good shape and the bendix is free to move. also verify that the solenoid throws the pinion out to engage.
You can bench test the starter to verify operation.
Also check condition of the ring gear via the starter mounting hole.
