Nortel 1140E Logo
Posted on Mar 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1140E phone upgrade
We are trying to upgrade the nortel 1140E SIP phone from 06A4XC39 to 0625C1B. Change cfg file and sipcfg file, put in new bin file on the tftp server, when the the phone is rebooted it comes back with the error (FW failed no signature found) don't get it.
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Oct 14, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
12585
Points
12
C1B is ancient UNIStim firmware. You cannot downgrade to it. Try converting to a more recent UNIStim version. You can download firmware from www.nortel.com/support.
MrHandyman2
Level 2:
Sergeant:
Habit-Forming:
  • Expert 106 Answers
  • Posted on Jan 26, 2016
MrHandyman2
Expert
Level 2:
Sergeant:
Habit-Forming:
Answers
106
Questions
0
Helped
66062
Points
605
Why would you want to downgrade you software to old version? Also, check the user's manual for more info: Nortel 1140e manual Download Free Manuals
2answers
NORTEL IP 1140E + BT 2 WIRE ROUTER.
Try a different phone on the same router, does that fix it?
2answers
Can two way speakerphone be disabled on a 1140E?
Yes - download the opperator manual from net at
http://www.nd.gov/itd/files/services/voice/1140e-user-guide.pdf
You can use the mute feature to block 2 way speech
2answers
I'm having trouble transfering calls on my Norton IP 1140E. Every now and then when I take a call, the 'transfer' label hops over to a different button and I'm completely unable to transfer...
Hello, depending on the status of the call the buttons will change automatically. Be aware that you may not be the initiator of the call so you may not have all the features. I hope this helps. If not you may contact me at: http://www.liveperson.com/nortel-guy
1helpful
Hello, I have a Nortel 1140e with SIP firmware that has been configured to work with my home VOIP system. The basic features work, but the phone doesn't ring on incoming calls and there's an audio delay...
First I will suggest you to upgrade the Firmware....check the ringer tune and volume is OK ... or try pressing Feature key * 6 and Press 1,2,3,4 or next to hear different type of ring types .....Press OK to save it....Now Try....Further result please let us know...Thanks for being with Fixya....Good Luckmoz-screenshot-1.pngmoz-screenshot.png
1helpful
2answers
Cannot activate light on feature keys display
You need to use an AC power supply on the base IP Phone 1140E for the backlight on the Expansion Module to work.
2answers
Nortel 1140E IP Phone, Expansion Module 1100 series not working
is it a bcm 50?bcm 50 must be version 3.0 release for module to work.
2answers
I have nortel phone ip 2002 i want use for my own carrier i need to reset
1. Reset the phone by disconnecting and re-connecting power.
2. When the Nortel logo appears, press each of the four soft keys in sequence.
3. If no other configuration changes are required, press OK repeatedly until the “PC
Port? 1-ON 0-0FF
” option appears.
4. Press 1 to enable the PC Port or 0 to disable the PC Port.
5. Select OK to confirm the change.
6. Restart the IP Phone.
When the IP Phone is restarted, the firmware sets the PC Port status accordingly
2answers
Nortel IP Phones I2004 and 1140e lose connectivity
here you are...
This could be the problem with your signaling server , have you checked it ??
I think it is losing connectivity of T-Lan Network.
1140E Problem
Is it the only IP phone? Howstable is the network?
Top Nortel Computers & Internet Experts
MrFixitSTTL
MrTrekot
MrTrekot
Garatuss
Garatuss
Level 1 Expert
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
