Ingrid Briody Posted on Apr 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Minolta Copier - 1031F - How do you clean the drum and the brushes
Chris Coughlin
Level 2:
  • Minolta Expert 1,326 Answers
  • Posted on Apr 06, 2010
Chris Coughlin
Minolta Expert
Level 2:
Answers
1326
Questions
Helped
441759
Points
872
Are you asking how to clean the drum and cleaning blade? If so, it is not worth the time if you don't replace both of them at the same time. There is one screw that hold the unit in. Then it slides out.. This Model was designed to replace the 2152 series.. It is a very Bad design.... Good Luck
COPIES HAVE BLACK INK ALL OVER PAGE
Pull out the image unit. have the drum removed check the cleaning blade is it yellow replace it. IF you can fine run ! Clean the drum off be careful no liquids USE a clean brush. NO vacuum cleaner the static electricity from the vacuum cleaner can destroy the Developer sensor (Unless you know how to do it). Remove the Transfer assy. located below the drum (Push down and out From the rear also) clean also
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Ep 1030/1031F gets black strip down side of paper about an inch wide
Odds are you need a new drum cleaning blade. The only problem is trying to find parts for the copier. Good Luck
How to change minolta ep1031 drum cleaning blade
It is not hard to do... The question is are you a service tech or just want to do it your self. If you are not a tech, it is best to leave it to someone who knows how to do it. It can & will get ugly fast if your not sure on how to do it......
I have a ep1031 minolta copier which started to leave blank marks all over my copies. while looking at the drum i could see the ink all over it so i took it all appart and cleaned the drum and the blades....
the issue you have is that the cleaning blade is worn and you will need to replace the cleaning blade This will fix your issue also make sure the fuser rollers are clean
2answers
My minolta EP3000 CSPRO shows error code coooo
Minolta ep3000 Cspro error code c0000 is plz sloved it
Ghost lines on paper. Is the drum bad?
cleaning blade out of order can caused black line.
3helpful
I have a Minolta CS Pro EP 1031 Printer that makes streak marks
Drum cleaning blade has gone bad. Especially true if the streaks seem to get progressively worse as you run multiple copies. In other words run 10 copies. If the last one out is worse than the first one out it is the drum cleaning blade. Cheap part...around $25
Minolta Di3510f
probably your drum is dirty and machine needs cleaning.
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
