The cooling fan can be lubricated by peeling off the round label. If the motor shaft can be seen, use a drop of sewing machine oil on the shaft. If you can't see the shaft, there is a rubber plug covering it. Use something sharp to remove it then put a drop of oil on it. This is not a permanent fix, so order a new fan and replace it when you get it.
SOURCE: Hitachi CP-X250 LCD Projector
If both lights are flashing orange, that means that the bulb needs to be replaced and the filter needs to be cleaned. Make sure you reset the counters for both after you replace them.
SOURCE: hitachi projector cp - s210
hi there,
I have just done the exact same thing today. Press menu button on projector. Scroll (navigate) to the mirror option. This give you the options to mirror image left to right or up and down.
This should fix any of your problems.
Cheers
Luke
SOURCE: Hitachi CP R555 Multimedia LCD Projector
Hi there
In your Menu options there is a subfolder where it either reads lamp or lamp timer.
Scroll down to it and hold down you right or left arrow key on the Projector for a couple of seconds.
SOURCE: Hello Wardens wife
Hi Airbala
This Projector does have a filter timer.
Go to the Options Menu and select Filter Time - then reset it.
SOURCE: hitachi projector temp light
This is what your projector's user manual says about a flashing "TEMP" light :
"The cooling fan is not operating. Turn the power OFF and wait approximately 20 minutes. After the main unit has cooled down, please make confirmation that no foreign matter has become caught in the fan, etc. After performing any needed maintenance, turn the power ON again; if the same display is displayed, then please contact a sales store or a service company."
Your user manual is available at the following link :
http://www.hitachi.us/Apps/hitachicom/content.jsp?page=Products/SupportServices/Support/DiscontinuedModels/index.html&level=4§ion=Products&parent=DiscontinuedModels&nav=left&path=jsp/hitachi/forhome/DisplayTechnologiesGroup/
