20 Most Recent Hitachi CP-X327 Multimedia Projector Questions & Answers
0answers
2answers
Lamp
lamp duration
2/16/2014 7:05:35 AM • Hitachi CP-X327... • Answered on Feb 16, 2014
The lamp has failed to go on for my hitachi cpx1 xga projector, it gives a green power on power then ren red on power&temp but nothing on lamp. what can i do to fix this?
Call hitachi service center to fix it. It may have a circuit problem or the lamp itself is deffective.
2/1/2014 2:51:04 PM • Hitachi CP-X327... • Answered on Feb 01, 2014
5answers
Lamp
I have the CP-X275W that did the same thing. The ballast was bad and I fixed it with a $5 switching regulator. The CP-X327 has the identical ballast.
Details:
The High Intensity Discharge Metal Halide lamp suddenly failed to light up. A new lamp was installed and would not light up either. The fan ran and the lamp LED flashed after a few minutes. Voltage to the ballast module was 368VDC. The ballast did not pulse.
Ballast# PS-226-LS-210 was bad. Hitachi Part# HA01101 has been discontinued and the new part number is HA01102. It was $210USD at Vance Baldwin or $221USD at Part Solver.
The FET series (TR1,5,6,7,8,) seemed good: (drain-source resistance=5Kohm). Bought an identical projector on Ebay to do comparative multimeter measurements. Found resistance differences in IC01 (STRG6153). Swapped good part to bad projector, and it worked. This is a 5-pin Sanken brand switching regulator, US$5 at www.electronix.com. They have the STRTG6153, which is compatible, and may be better. The bad one removed from the circuit measures 15Kohm on pin 3 to pin 5 and the same 15Kohm when the probes are reversed. The good one measures 18Mohm and infinite when the probes are reversed.
If you would like me to fix it for you and clean all your optics, I can do it for $150USD plus $25 return shipping. Contact Chris at [email protected].
If you have a new lamp for sale I would buy one for $100USD.
Good luck.
11/28/2013 9:04:44 PM • Hitachi CP-X327... • Answered on Nov 28, 2013
0answers
0answers
Red lamp
Be the first to answer 11/28/2011 3:50:06 AM • Hitachi CP-X327... • Posted on Nov 28, 2011Be the first to answer
I cant see any light from the projector bulb. it
what are the state of the leds on the top cover as it tries to start up, and what finally do the leds indicate when it gives up trying
3/7/2011 9:12:48 AM • Hitachi CP-X327... • Answered on Mar 07, 2011
My Hitachi CP-X275 Multimedia Projector
Normally when a unit like this shuts down, there are indicators that will show why. Are any of the lights on or blinking when this happens? The most common cause is overheating. Is the lamp indicator RED or the temp indicator? A little more detail would be helpful here. Can you also indicate how long the unit runs before shutting down?
Thanks,
Dan
11/4/2010 9:30:38 PM • Hitachi CP-X327... • Answered on Nov 04, 2010
Problem with Lamp when starting the projector.
Try changing the lamp
5/25/2010 11:54:25 AM • Hitachi CP-X327... • Answered on May 25, 2010
The projector does not light
Make sure you reinstall the door to the lamp, if it is installed correctly then the lamp ballast or sometimes called the lamp driver is at fault,
12/21/2009 6:37:20 AM • Hitachi CP-X327... • Answered on Dec 21, 2009
No lamp
whats your location, The power supply is faulty, but fairly easily repaired, if you send it to me, I will sort it out
3/9/2009 2:19:14 AM • Hitachi CP-X327... • Answered on Mar 09, 2009
No picture from projector after changing lamp
how to change the lamp
10/11/2008 7:12:35 AM • Hitachi CP-X327... • Answered on Oct 11, 2008
Not getting any scrren at all.
is the cooling fan working? - usually if a bulb replacement doesn't solve the problem, and it has been installed correctly, then the safety overheating cutout may be preventing the bulb from working due to a cooling problem - check the fan spins and sound healthy, check all the yents / filters are clear and if you can see the blades, see if they are particularly dirty/dusty. If the fan seems to be fine then the safety cutout itself is likely to be faulty - contact hitachi; http://www.hitachi.co.uk/service/index.jsp And they should be able to give you the details of the nearest service to you. Hope this helps :)
3/22/2007 7:24:49 PM • Hitachi CP-X327... • Answered on Mar 22, 2007
Hitachi CP-X3030WN 3 LCD Projector. I would like a manual diagram data to show Hitachi CP-X3030WN 3LCD Projector power supply.
Power Supply is $50 https://www.google.com/search?q=hitachi+cp-x3030wn+power+supply
CP-X2530WN/CP-X3030WN CP-WX3030WN
Projector Central https://www.projectorcentral.com > pdf > projecto... The information in this manual is subject to change without notice. • The illustrations in this manual are for illustrative purposes. They may differ. 118 pages
Hitachi in Europe https://estadoc.hitachi.eu > servlet > FileViewer The information in this manual is subject to change without notice. • The illustrations in this manual are for illustrative purposes. They may differ. 69 pages
CP-X2530WN/CP-X3030WN/CP-EX250/CP-EX300 ...
Projector Central https://www.projectorcentral.com > pdf > projecto... EW300. Responsible Party Hitachi America, Ltd. Address. 900 Hitachi way, Chula ... Before connecting the projector to a device, consult the manual of the device ... 20 pages
12/4/2023 11:23:45 PM • Hitachi Office... • Answered on Dec 04, 2023
Hitachi CP-X327 Multimedia Projector Logo
21 questions posted
Top Hitachi Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
old marine
old marine
ZJ Limited
ZJ Limited
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Office Equipment & Supplies
Most Popular Question
problem lamp when starting projector
  • Office Equipment & Supplies
