20 Most Recent Hitachi CP-X325 Multimedia Projector Questions & Answers
I am trying to connect
That is because MAC use a different standard from IBM. You may need an adapter. Available from a local PC store or online.
3/3/2011 3:08:31 PM • Hitachi CP-X325... • Answered on Mar 03, 2011
6answers
How to check for lamp life of my mitsubishi multimedia Projector xd 450u (DLP)
i believe you hit the up and down arrow and the enter button on the projector itself and hold hem in for few seconds and it will display lamp usage.
10/5/2010 9:30:53 AM • Hitachi CP-X325... • Answered on Oct 05, 2010
The projector works find with my pc but not on my
this model does not support mac so dont waste ur time
8/15/2009 5:51:24 AM • Hitachi CP-X325... • Answered on Aug 15, 2009
Determine if the lamp works without installing it into a projector
HI there
The only sure way is to put them in a Projector , because they might for example start up , but swith off again after a couple of minutes or seconds.
If there is no visible damage on them , they will most probably be ok.
4/16/2008 9:52:41 AM • Hitachi CP-X325... • Answered on Apr 16, 2008
Hitachi CP-X3030WN 3 LCD Projector. I would like a manual diagram data to show Hitachi CP-X3030WN 3LCD Projector power supply.
Power Supply is $50 https://www.google.com/search?q=hitachi+cp-x3030wn+power+supply
CP-X2530WN/CP-X3030WN CP-WX3030WN
Projector Central https://www.projectorcentral.com > pdf > projecto... The information in this manual is subject to change without notice. • The illustrations in this manual are for illustrative purposes. They may differ. 118 pages
Hitachi in Europe https://estadoc.hitachi.eu > servlet > FileViewer The information in this manual is subject to change without notice. • The illustrations in this manual are for illustrative purposes. They may differ. 69 pages
CP-X2530WN/CP-X3030WN/CP-EX250/CP-EX300 ...
Projector Central https://www.projectorcentral.com > pdf > projecto... EW300. Responsible Party Hitachi America, Ltd. Address. 900 Hitachi way, Chula ... Before connecting the projector to a device, consult the manual of the device ... 20 pages
12/4/2023 11:23:45 PM • Hitachi Office... • Answered on Dec 04, 2023
MESin basuh Hitachi sf-105s saya tidak bisa hidup.saya sudah menukar pcb board control dengan yang baru..tapi mesin masih tidak boleh hidup
Jika mesin basuh Hitachi SF-105S Anda masih tidak dapat menyala setelah Anda mengganti pcb board control yang baru, maka ada kemungkinan bahwa masalahnya terletak pada pcb power board atau bagian lain dari mesin. Untuk menentukan apa yang perlu diganti, ada beberapa langkah yang dapat Anda lakukan:
  1. Periksa kabel daya dan sambungannya untuk memastikan tidak ada kerusakan atau kelonggaran.
  2. Periksa bagian lain dari mesin, seperti switch atau saklar, untuk memastikan tidak ada yang rusak atau tidak berfungsi dengan baik.
  3. Periksa pcb power board untuk mencari tanda-tanda kerusakan, seperti komponen yang terbakar atau terkelupas.
1/3/2023 11:35:14 PM • Hitachi Office... • Answered on Jan 03, 2023
Please tell me how to fix Fd error code of Hitachi washing machine SF-90HJ.
https://producthelp.whirlpool.com/Laundry/Washers/Top_Load_HE_Washers_(Oasis)/Error_Codes/Fd_-_Error_Code_-_Washer
Fd means Factory Default settings.
A Fd (Factory Default) error code indicates that the washer was set back to factory default settings. To return all options and modifiers to Factory Default, press POWER/CANCEL, select Drain & Spin cycle, and then press Extra Rinse, Fabric Softener, Extra Rinse, Fabric Softener within 5 seconds. When done correctly, the 7-segment displays show "Fd" for 3 seconds and then unit returns to Standby Mode.
10/3/2022 4:15:57 PM • Hitachi Office... • Answered on Oct 03, 2022
What causes my Hitachi CP-TW2505 LCD projector to have a green hue?
It goes with the territory of old technology. There is lots of help in the link. https://www.google.com/search?q=Hitachi+CP-TW2505+LCD+projector+green+hue ..
10/15/2021 9:44:57 PM • Hitachi Office... • Answered on Oct 15, 2021
I lost the remote, and accidentally put the key lock on, on my Hitachi cp-x301 projector and not I can only turn it on and off.
https://www.hitachi.com.au/documents/dps/CPX301_manual.pdf Apparently, the usb port on the back can be used to plug in a simple mouse and keyboard to control the projector.
9/27/2020 2:01:54 AM • Hitachi Office... • Answered on Sep 27, 2020
HiTaChI pRinTeR inStaLlAtIoN sUpPoRt nUmBeR $1.{877}*{76.9}*{09.69}*#$ 24/7
BILLY, Your message does not qualify as a question or query for a problem, try somewhere else DO NOT MAKE THIS SITE WITH YOUR GARBAGE Take your GARBAGE to another Side Your message qualifies as SPAM
11/6/2019 3:45:50 PM • Hitachi Office... • Answered on Nov 06, 2019
The temp light on my Hitachi projector is constantly red. what does this mean?
Hi Sam, the temperature light, tells you that the ventilation system is not working properly As a first step, remove the filter (s) and clean them well or replace them with new filters. It would also be important to do an interior cleaning, do not use torches or air sprays, since they can do more damage than solution, always try to vacuum dirt I hope you can make your Hitachi work properly Regards Franco Dosil Hola Sam, la luz de temperatura, te indica que el sistema de ventilacion no esta trabajando correctamente Como primera medida , saca el o los filtros y limpialos bien o reemplazalos por filtros nuevos Tambien seria importante hacer una limpieza interior, no utilices ni sopletes ni aerosoles de aire, ya que pueden hacer mas da?o que solucion, siempre trata de aspirar la suciedad espero Puedas hacer funcionar correctamente tu Hitachi Saludos Franco Dosil
8/13/2019 5:40:49 PM • Hitachi Office... • Answered on Aug 13, 2019
Hi, my Hitachi CP-X445 projector will not stay running for more than 5 minutes when mounted feet up, but there is no problem running feet down, any ideas?shuts down on high temp Thanks, Jose
the lamp is not good you need a Original lamp I Supply the Projector accessories,in China. projector accessories:Laser Diode Module,lamp,bulb,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast...with high quality and competitive price. Hope to cooperate with you. Lampdeng Co.,Ltd. (Guangzhou, China) is founded in 2000, is a major supplier of projector lamps www.Lampdeng.com
5/31/2019 4:17:52 AM • Hitachi Office... • Answered on May 31, 2019
I have a yellow spot on my Hitachi cpx10000 projector.
the Lcd panels are fault or the polarizer isfault I Supply the Projector accessories,in China. projector accessories:Laser Diode Module,lamp,bulb,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast...with high quality and competitive price. Hope to cooperate with you. Lampdeng Co.,Ltd. (Guangzhou, China) is founded in 2000, is a major supplier of projector lamps www.Lampdeng.com
5/31/2019 4:13:36 AM • Hitachi Office... • Answered on May 31, 2019
What could have happened to the projector to get a large blob that changes shape and is purple colored. Like an amoeba that grows and moves around.
Font strokes are not cleaned Black silk font is not black enough reason: the Lcd panels are fault I Supply the Projector accessories,in China. projector accessories:Laser Diode Module,lamp,bulb,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast...with high quality and competitive price. WhatsApp ID:+8613178867858 Skype:[email protected] Wechat ID:+8613178867858 Email:[email protected] Email:[email protected] Mobile:+86 13178867858 http://www.lampdeng.com
5/31/2019 4:08:56 AM • Hitachi Office... • Answered on May 31, 2019
My hitachi A120n projector has no power light checked internal fuse and ok .
The power indicator is off. two reason: 1,the mainboard is fault 2,the powersupply is fault I Supply the Projector accessories,in China. projector accessories:Laser Diode Module,lamp,bulb,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast...with high quality and competitive price. WhatsApp ID:+8613178867858 Skype:[email protected] Wechat ID:+8613178867858 Email:[email protected] Email:[email protected] Mobile:+86 13178867858 http://www.lampdeng.com
5/31/2019 4:06:48 AM • Hitachi Office... • Answered on May 31, 2019
Hitachi projector cp-wx3041wn problem Power & temp light on ? How to solve
You should clear the air filter and reset the air filter timer and the lamp timer menu-advance-option-reset the air filter menu-advance-option-reset the lamp filter I Supply the Projector accessories,in China. projector accessories:Laser Diode Module,lamp,bulb,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast...with high quality and competitive price. WhatsApp ID:+8613178867858 Skype:[email protected] Wechat ID:+8613178867858 Email:[email protected] Email:[email protected] Mobile:+86 13178867858 http://www.lampdeng.com Posted on May 31, 2019
5/31/2019 4:05:41 AM • Hitachi Office... • Answered on May 31, 2019
Hitachi cp-rx60 not powering Temp led light blinking red non stop what could be the problem
you should clear the air filter and reset the air filter timer menu-advance-option-reset the air filter I Supply the Projector accessories,in China. projector accessories:Laser Diode Module,lamp,bulb,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast...with high quality and competitive price. WhatsApp ID:+8613178867858 Skype:[email protected] Wechat ID:+8613178867858 Email:[email protected] Email:[email protected] Mobile:+86 13178867858 http://www.lampdeng.com
5/31/2019 4:04:31 AM • Hitachi Office... • Answered on May 31, 2019
Hitachi CP-X325 Multimedia Projector Logo
8 questions posted
Top Hitachi Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
old marine
old marine
ZJ Limited
ZJ Limited
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Office Equipment & Supplies
Most Popular Question
determine lamp works without installing
  • Office Equipment & Supplies
