Hi I have a Samsung SGH-A867 cell phone that I truely love. I have only one problem with it and that is the ringtone does not ring long enough. Is there a way to make it longer? My setting is set on 7 (max) but is really too short. Can I buy a ringtone that plays longer? I really need help because I changed over from Motorola phones to Samsung and I really like the Samsung much better except the ringtone lenght. Please Help.. jd
SOURCE: changing the ringtone
actually jkhnetx i can help you address those problems
if you want it to ring and vibrate at the same time, do the following:
1. open phone, and push the side key under the memory card slot.
2. scroll over to the 'PROFILE' setting
3. highlight the 'NORMAL' setting, and push the 'OPTIONS' key.
4. go to 'EDIT'. push 'CALL ALERT' and you get a wealth of options. you can also edit the MESSAGE and PHONE SOUNDS options.
cheers!
SOURCE: I have a Samsung SGH-A867
You cant fix it. ATT knows its a problem but are not doing anything about it. All thats needed is for them to make sure the file has a JPG extension and not JPGG. I spent about 1.5 hours on the phone with them about it and all they are willing to do is take off half of your messaging bill (about $10).
Basicly the only real fix is to switch to verizon or sprint
SOURCE: SGH-A867 Samsung unlock code. I am trying to
USE ALL * AND # INCLUDED WITH CODE .PLACE DIFFERENT SIM CARD IN PHONE ANY OTHER THAN ORIGINAL DONT WORRY THE CARD WONT BE HARMED READY LETS TRY?ENTER THIS CODE
*7465625*638*00000000*00000000#HIT END KEY ONCE THEN ENTER *2767*2878# WAIT 10 SECONDS PHONE WILL REBOOT NOW ENTER #745625*638*00000000# PHONE SHOULD BE UNLOCKED NOW TRY YOU SIM AND SOMEONE ELSES YOU CAN USE DIFFERENT NETWORKS NOW GOOD LOCK.
SOURCE: My samsung sgh-a867 is not working. It turns off
check your battery first by using another phone or the problem is with your mobile phone
SOURCE: how to reset my Samsung Eternity SGH-A867
Master-Reset: all personal data will be deleted *2767*3855#
