Yukon Linear Counter Balanced Smith Machine Logo
Posted on Mar 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is linear counter balance,What is the advantage
John Mazmanian
Level 3:
President:
  • Master 832 Answers
  • Posted on Apr 10, 2010
John Mazmanian
Master
Level 3:
President:
Answers
832
Questions
0
Helped
628635
Points
2056
The linear is the bearing they use for smooth motion up and down the guide poles, If you use an assisted chin dip unit its a similar concept it take some of the weight off the bar.In my opinion the Smith Machine promotes poor lifting form and puts the lifter in more danger than the traditional power cage.
1helpful
Is there a standard size for a kitchen countertop?
A linear foot is 12 inches wide and 25 inches deep because the standard depth of kitchen countertops is 25 inches.
The Americans with Disabilities Act Accessible Guidelines state that space at least 30 inches wide should be accessible, meaning that wheelchair users can roll up to the counter to perform tasks. The counter should be between 28 and 34 inches high and accommodate a minimum 27-inch knee clearance below the counter, sink or cabinet space. Anything beyond the first 16 inches of counter depth, from the front edge, is considered dead space for wheelchair users.
1helpful
Whats my otc ballance
https://www.archcare.org/health-plans/archcare-advantage/your-benefits/over-counter-otc-card
You can call the phone number or go to the web site shown.
CHECK YOUR BALANCE You can check the balance on your OTC card at any time by:
  • calling 1?888?682?2400. You will be asked to enter your OTC card number.
  • or by visiting www.otcmember.com. Once on the site, you will be asked to enter your OTC card number.
  • or by calling Member Services at 1?800?373?3177 (TTY/TDD: 1?800?662?1220), seven days a week from 8:00 A.M. to 8:00 P.M.
1helpful
We have a GE washer and it keeps making the load unbalanced
some G.e s have an inertia balance switch when it goes bad u have a bad balance error, also u may want to check the counter weights, counter balance rods, or bad damper pads. also check to see if the machine is off balance on the floor?
1helpful
I just asked about my washer vibration and did you answer my comp. kicked out and I did not get my answer
Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Drum wobbles when empty
Marantz pmd520
The PMD520 doesn't have balanced XLR inputs; only unbalanced phono/RCAs. If your source has phono outs too, then use those, because the benefit of balances inputs is lost when converted to phono.
If you still want to go ahead, then buy some balanced to unbalanced converters.
Studiospares RED502 Bi Directional Balanced Unbalanced Converter
If you try to do this on the cheap by wiring an XLR to phono, be aware that the studio level output of balanced level connections is about 2V rms. The live input level for unbalanced is around 1V rms. You'll either need to pad the input to reduce the level or run the cassette REC level controls nearer to the bottom of their adjustment range where they're a bit noisier and not so linear.
Tub is crooked, could a balancing spring come loose
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
By the way my advice is free cuz God is good!
Genie model ACSD1G will not program to Linear door opener model # LD033.-- need help doing this.
Most of the time, keypads and remotes are not compatible with other manufacturers. You would be better off getting a universal keypad, which should work. Double check the older opener to make sure it is on the list of compatible devices.
Also, make sure you check the balance of your garage door periodically to make sure your springs are counter-balancing the garage door properly. If not, the lifespan of the garage door opener will be substantially shortened. Click here for a how-to video.
It much smoother more control usage than bushing smith machine that will drag
3helpful
My washing machine door says that it is locked when the door is open how can I fix this?
Replace the door switch, but,..... if you order the switch, they may send the switch in a rather large and heavy (and somewhat expensive) box which also contains the lower counter balance for the front of the drum. The reason is that on some machines, the counter balance is shapped in such a way that on certain off balance loads, the counter balance is able to strike the door switch and break it. The new counter balance weight has been re-designed to prevent this from occuring.
Top Yukon Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a Yukon Exercise and Fitnes Expert? Answer questions, earn points and help others
