20 Most Recent
Genie Company Genie Gwkp Keypad Replacement Cover Sandstone 35365t Questions & Answers
Genie model ACSD1G will not program to Linear door
Most of the time, keypads and remotes are not compatible with other manufacturers. You would be better off getting a universal keypad, which should work. Double check the older opener to make sure it is on the list of compatible devices.
Also, make sure you check the balance of your garage door periodically to make sure your springs are counter-balancing the garage door properly. If not, the lifespan of the garage door opener will be substantially shortened. Click here for a
how-to video.
Key pad stopped working
Have you changed the battery in it? Most often, this is the cause for key pad failure. Or if you have already changed the battery, is the + & - facing the proper direction?
Genie home alarm system keeps beeping
Find your user manuel. If you do not have it type in the system you have into Google and put "user manuel" after it. (i.e. Genie user manuel) Look in the table of contents under the troubleshooting section and follow the steps listed. The exact panel type should be searched for Genie...then there should be some model number.
NED 8700 smart button location
a marantec ned8700 has no smart button you have to open the remote n remove the battery then connect the programming 3-prong cable to the terminal on the side of the remote (under the rubber cover) the with a flat screwdriver short out 2 of the prongs one must be the center prong. press and hold the button on the remote that is active, in 2 seconds code will change. elease the button after the light illiminates continuously then remove the programming cable/prongs and replace battery n cover then press n release p button on machine till only 7 lights up take remote hold it 3'' away from button and press button on remote to program for 10 secs release then push p button on machine once, 8 will light up and your set to go
