Our Maytag microwave died today. The power outlet has power, but not the oven. Where are the fuse located, so that I can check to see if that is broken?
You have to remove the cover, un-plug the power cord=
un-screw the screws located behind the unit and on the sides if any also under side if any, remove cover and you will locate the fuses and other components behind the key pad, also check slow blow or thermal fuse usually located on top of oven. NB: HIGH VOLTAGE COMPONENTS PROCEED WITH CAUTION!!!!!!!
