20 Most Recent Maytag MMV1153A Microwave Oven Questions & Answers
Outside light wont go on!
Get the manual from web site.
6/28/2017 9:16:54 PM • Maytag MMV1153A... • Answered on Jun 28, 2017
3answers
Microwave won't heat food.
built in 3/94 is it worth fixing how much for magetron
9/27/2015 1:42:48 AM • Maytag MMV1153A... • Answered on Sep 27, 2015
When I shut the door on the microwave the turntable starts running even though it's not turned on and the light stays on
Maybe a failed triac that switches the motor and light. Also try pulling it out from the wall for some time.
3/16/2015 10:58:22 PM • Maytag MMV1153A... • Answered on Mar 16, 2015
2answers
My Maytag microwave has error code "SE" on the
SE error means you have a shorted membrane keypad.
The full model number would be MMV1153AAB or MMV1153AAW and denotes color.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly ("control panel/switch" as it's called) which comes with a new keypad.
It's actually a pretty easy do it yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Next, disconnect the strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Some connectors have a lock:
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
You can get the part from the Pros here. They're our favorite supplier.
You can also find helpful exploded view diagrams at that link.
2/3/2015 3:57:00 PM • Maytag MMV1153A... • Answered on Feb 03, 2015
Where r fuses at on mmv1153ba
If power turns on or interior light goes on, it is not the fuse.
11/26/2014 5:42:23 PM • Maytag MMV1153A... • Answered on Nov 26, 2014
Nothing on my touch pad works
My microwave way manafacture May 2008. Nothing on the touch pad works.???. It just abrubtly stopped
after a few seconds.
We brought it in July or August
Debbie
8/3/2014 10:40:55 PM • Maytag MMV1153A... • Answered on Aug 03, 2014
Door doesn't latch
Can you move the latch in the door? This is spring loaded, maybe the spring is broken
2/11/2014 1:34:02 AM • Maytag MMV1153A... • Answered on Feb 11, 2014
5E display on maytag microwave
<- Let me know your full model number from the tag on your oven so I can give you detailed information repair. Unless there is grease or moisture on your control circuit board, "SE" means you have a shorting membrane keypad.
1/9/2014 4:28:49 AM • Maytag MMV1153A... • Answered on Jan 09, 2014
Does not work
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
7/20/2013 11:39:00 PM • Maytag MMV1153A... • Answered on Jul 20, 2013
2answers
Maytag MMV1153AAW microwave
I have the same problem with mine!!! I spent 58 dollars to have a 6 dollar diode replaced. Now 8 months later... same prob. Replaced again myself and working fine again. Just make sure you label the wires while working on it. I didn't and it cost me 2 new fuses! Hope this helps.
5/22/2013 9:01:25 PM • Maytag MMV1153A... • Answered on May 22, 2013
How to replace the battery for a 2010 BMW 750Li remote key?
I think the battery is under the back seat
3/13/2013 3:05:30 AM • Maytag MMV1153A... • Answered on Mar 13, 2013
3answers
It just quit while cooking. Is there afuse in this
If the model number is correct, there is a 125V, 20 AMP line fuse inside the microwave. Its usually mounted at the point where the power cord enters the back of the unit. You will need to UNPLUG the microwave oven and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at pcappliancerepair.com based on the model number you listed this question under:
http://pcappliancerepair.com/model-display.php
The line fuse is listed as item 12.
You can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended.
If you have any questions, or need additional assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit.
12/13/2012 10:51:36 PM • Maytag MMV1153A... • Answered on Dec 13, 2012
Maytag MMV1153A Microwave Oven Logo
160 questions posted
Top Maytag Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Microwave Ovens
Most Popular Question
door doesn 39 t latch
  • Microwave Ovens
