HP PSC 2210 All-In-One InkJet Printer Logo
Posted on Mar 12, 2008
Lexmark 5400 series
I am having a problem with my scanner. The display is reading CANNOT RETRIEVE APPLICATION LIST. I have made my setup, refer to trouble shooting and not getting any results. What am I doing wrong?
  • 2 more comments
  • Vanber Apr 21, 2008
    I press Scan Mode On my Lexmark 5400 series all in one. It wrote: cannot retrieve application list. What should I do?
  • one1love3 Jun 29, 2008
    exact same problem
  • 012659 Feb 06, 2009
    when i press the scan mode the screen reads cannot retrieve application list
  • cms770 Apr 03, 2009
    i just scanned something now it is telling me it cannot retreive application list
fbyrd99
Level 1:
  • Contributor 10 Answers
  • Posted on Jul 26, 2008
fbyrd99
Contributor
Level 1:
Answers
10
Questions
0
Helped
14036
Points
30
Problem: Lexmark cannot retrieve applications list
I have the Lexmark X3550 with the WiFi option board installed (makes it same as the model X4550) and get the “cannot retrieve applications list” message on one of the five computers connected to my router (Linlsys WRT54G V8) and using wireless printing and scanning. Just like everyone else with a similar Lexmark WiFi printer/scanner, I can print wireless, but cannot get the wireless scanner to work on one of my PCs.
The fix, in my case, was to change the Lexmark network name as follows.
1. Launch Lexmark Imaging Studio.
2. Right-Click on “View or change network settings”.
3. Enter a new network name in the first box shown. (This box contained the correct network name for my PC, but another name was needed to make the scanner work. I simply added “-lex” at the end of the current network name.)
4. Right-Click OK. You should return to the Imaging Studio screen.
5. Close the Lexmark Imaging Studio window. (The tray icon should remain at the screen lower right.)
6. On the printer, press the Scan Mode button.
7. On the printer’s display screen, select the Computer Name that you entered for the new network name. Just use the arrow buttons until the exact name is shown.
8. Press the Check button. The display screen should show “Downloading Applications List”. Within about 10 seconds the message should change to “ *Scan to Computer ”. Wireless scanning should now work.
9.. Press the Start Color or Start Black button. “Requesting Scan” will be shown. After a few seconds scanning will start. The process is a bit slow.
10. After a while you may see an empty small Lexmark window onscreen. Later, the Lexmark Imaging Studio will appear onscreen, then change to show many options and features. An image of the scanned item will appear in a Lexmark window. Save and/or edit the image. Another scan can be done by pressing the printer’s Check button again. Be sure the correct computer name is shown on the printer’s display.
That’s it. A new computer name was the solution. Your PC and printer may require a restart (power off) after changing the “computer name”.
Regards, Fbyrd
  • tdwriter Sep 16, 2013
    I have a X6675 and this fix worked for me. Thanks!
WillieL
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 13, 2008
WillieL
Contributor
Level 1:
Answers
Questions
Helped
1810
Points
I was trying to setup from the printer, when I should have been setting up from the desktop.
A
Anonymous
Take it back to the shop, get a refund and buy an Epson
1 Related Answer
Anonymous
  • 564 Answers
  • Posted on Aug 19, 2008
SOURCE: Lexmark 5400 series
hmmm..what are you using for the scanner function?
http://tinyurl.com/6qcpgy
Have a Lexmark X5470; when 'Scan Mode' is engaged,
on your computer: click on start all programs / programs check for the lexmark folder ( lexmark 5400 Series ) check if there is any application under it ( AIOC , Productivity Studio, or Imaging Studio ) If there is: check your firewall, this might be blocking the application list. If there's none: Using the disc: Start My Computer / Computer Open your CD/DVD drive where the lexmark disc is Open application folder Run Setup under application folder. This should update the software
Lexmark Scanner - "cannot retrieve application list" Won't Scan - HELP please!
delete the norton internet security as its blocking the scanner files of your printer software .or try reloading the printer drivers again but if reloading the printer drivers does not helps then removing the norton software is compulsary as the files of printer are getting blocked so scanner is not working.
12helpful
3answers
Microsoft Paint ----> 'File' ------> 'From scanner or camera' (when in scan mode on printer). Just tried this and it really works.
Lexmark x5470
is this scanner plugged into a power strip by chance.plug it directly into the wall power
Lexmark 5400 series
10helpful
4answers
Lexmark 5400 series all-in-one fax printer scanner copier
This is not so much a solution, but I have a lexmark 5400 printer -and I am also having problems with "alignment." I just replaced the cartridges an now I am getting an error message saying: "Alignment problem, remove tape from cartridges, check paper and then press the check-mark button." There does not appear to be anything wrong with the cartridges (there shouldn't be - they're new), but the cartridges will not center when the cover is lifted. So I can no longer print anything, and I can't check the cartridges - help!
Any information anyone can provide would be greatly appreciated. I'd hate to replace the printer, it's still in very good shape.
Thanks
ok...try a test page first, with printer off the computer completely
and..check for newest printer drivers here
or send me an email, and I can make a shared service call today(Sunday)
[email protected]
4helpful
4answers
Lexmark X5470 scanner problem
i had the same problem but if you open the Lexmark All-In-One center (can be found in start --> all programs --> lexmark 5400 series --> all-in-one center) and select scan (it will work)
if you dont have the program installed find your installation disk and when u re-install it, it should come up again
SH33P
k24674
Grand Canyon Tech
Grand Canyon Tech
