Http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00495173/c00495173.pdf
Page 123
To set the number of rings-to-answer
To set or change the number of rings-to-answer, use the following steps:
1. On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Fax setup, and then press .
3. Use the < or the > button to select Fax Recv. setup, and then press .
4. Use the < or the > button to select Rings to answer, and then press .
5. Use the alphanumeric buttons to enter the number of rings-to-answer, and then press .
