When the single shower handle is turned all the way over to select the hot water the pressure slows to a trickle and the water never gets hot. There is plenty of pressure when the cold water is selected. All other faucets in the same bathroom have hot water and works just fine. Any suggestions to get the hot water running in the shower?
Adjust ur anti scold the setting is set to low when single handle shower units are shipped they are set in cold mode for safety ur install/instructional paperwork explains such and also advises on how to adjust---remove handle and on shaft will see a blue and red plastic clips that are adjustable slide towards u and move red for more hot water test water continue till comfort level is reached for hot water
Testimonial: "This information was extremely helpful especially when you know what to look for and have instruction."
SOURCE: When turning on the shower faucet there is no hot water.
Can you remove handle , behind handle there should be a dial to move to increase hot or cold supply.
Remember where you start and remove it and replace a 1/8 to 1/4 turn counter clockwise, just put handle on try it and see if it changes and adjust accordingly.
