20 Most Recent
Kohler K-T12007-4s-BV Brushed Bronze Fairfax Single Handle RiteTemp Tub and Questions & Answers
When I turn on the
Sounds like the cartridge inside the valve body may need replacing.
10/26/2010 7:36:45 AM •
Kohler...
Answered
on Oct 26, 2010
When turning on the shower faucet there is no hot water.
Can you remove handle , behind handle there should be a dial to move to increase hot or cold supply.
Remember where you start and remove it and replace a 1/8 to 1/4 turn counter clockwise, just put handle on try it and see if it changes and adjust accordingly.
5/17/2010 12:38:12 AM •
Kohler...
Answered
on May 17, 2010
High pressure
Are you sure it's not just that the shower heads are getting dirty from calcium build up, thus reducing the diameter of the holes in the head, which will in turn cause spray to come out at higher pressure. ( same idea as holding your thumb over the end of a garden hose) Try removing and either replacing head, or soak it overnight in C.L.R (available at any hardware store.) and clean it good and try it again.
5/3/2010 12:02:06 AM •
Kohler...
Answered
on May 03, 2010
adjust ur anti scold the setting is set to low when single handle shower units are shipped they are set in cold mode for safety ur install/instructional paperwork explains such and also advises on how to adjust---remove handle and on shaft will see a blue and red plastic clips that are adjustable slide towards u and move red for more hot water test water continue till comfort level is reached for hot water
3/24/2010 6:34:03 PM •
Kohler...
Answered
on Mar 24, 2010
Kohler KT12007 Showerhead
The device which directs the water up or down is called the diverter. Your diverter is not fully up or fully down. Rather forcefully push and pull the diverter a few times and your problem may be solved. good luck.
1/25/2009 3:29:41 AM •
Kohler...
Answered
on Jan 25, 2009
Need password for a stolen file
Okay. The question is a bit lacking in details. Password for what? Password ON what? Where was the file stolen from? Who stole the file? What is the file content. What is the file extension (the bit after the file name and the period file_name.what)?
All questions need to start 'make model (what it is)' first 3 words. And then a clear question.
For the 13 people that have tagged this 10 year old question, it is better to post your own question.
2/7/2024 6:03:08 AM •
Kohler Home
Answered
on Feb 07, 2024
