My tv shuts off and the timer, lamp and standyby/temp lights in the front on the power button flash on and off. It takes a couple of minutes for me to be able to turn it back on. this is a random problem most of the time i have no problems with it
This is a common issue with these. When the bulb fails it can put added stress on the power supply and cause parts in the supply to fail. They are not meant to be serviced by the end user. I would check to see if you can locate a parts source for the power supply.
Color Wheel - Pull out the Lamp using a flash light look right into where Lamp was you should see the color wheel turn TV on watch to see if wheel is turning,From what you have said Problem will be the Color Wheel. Encompass Parts Distribution has them 1-800-638-3328
replace the lamp only takes few min make sure you get right one for model of tv the LAMP MODEL number will be on OLD LAMP the tv will work and sound will come back hope this helps
