The noise is caused by the engine running on after the ignition is shut off. It makes noise because the pistons are rattling in the cylinders from incorrect timing. This has nothing to do with the mechanical or electronic timing of the engine. The engine runs on either because of hot glowing carbon deposits in the cylinder head or because the engine was shut down when it was running too fast. Sometimes the carbon can be literally blown out by running the engine at high rpm for a short time. Put it in second gear and run it for a couple of miles on the highway. If this does not work the heads will have to be removed and the carbon cleaned out manually. The shut down when running too fast problem can be caused by the idle being set too high or by shutting the engine off before it has reached idle speed. If you can adjust the idle speed try reducing it. If not always hesitate before shutting the engine down to let it reach idle speed. Good Luck!
Testimonial: "Thanks very much, Ill be sure to try this. This was a very knowledgable and easily understood response."
A "click" or "thump" noise can be caused by several factors, including:
suspension:
Loose or worn suspension components, such as control arm bushings, control arm connections, and struts, can cause rattling noises when climbing over bumps.
Drivetrain:
Worn or damaged drive shafts, constant velocity joints, or differential components can also cause rattling noise.
break:
Worn or loose brake parts such as calipers and rotors can cause a rattling noise when applying and releasing the brakes.
engine:
If the engine rattles, there may be a problem with the engine mounts or the timing belt.
These are just some of the possible causes of knocking noise and an accurate diagnosis can only be made by a specialist after an inspection.
TROUBLESHOOTING ENGINE NOISES
A KNOCKING SOUND IN THE ENGINE IS MOST LIKELY CAUSED BY ONE OF THE FOLLOWING
1. PISTON SLAP: Makes a sharp metallic noise. Idle engine and short out each cylinder plug. The noise will disappear when plug with bad piston is shorted. Noise will also disappear at acceleration. This can be caused by worn or out of round cylinder, or broken piston ring. Correct problem by re-boring cylinder and/or replacing piston.
2. VALVE NOISE: Makes clicking or rattle noise. Caused by excessive wear on valve stem or lifter, out of adjustment, or stuck valve. Correct by adjusting valve clearance, replace worn valve or lifter, regrind cam, replace valve guide and /or valve. A stuck valve can sometimes be loosened by passing oil through the carburetor while engine is running.
3. ROD BEARING KNOCK: Makes sharp metallic noise similar to a piston slap. Detection is opposite of piston slap. Rod knock is not heard at idle. Knock becomes louder as engine speed is increased. Caused by excessive rod bearing clearance. Correct by adjusting rod bearing clearance to .0015 inches by removing shims. May require re-pouring rod bearing.
4. REAR MAIN BEARING KNOCK: Makes dull knocking or thud noise. Detected at speeds between 20 and 50 MPH. Knock will normally decrease or disappear while pulling or decelerating. Noise will be detected the loudest at normal driving speed, when not pulling or decelerating. Correct by adjusting bearing clearance to .001 to .0015 inches. If knock is excessive, crank should be checked for out of roundness. May need to re-pour all main bearings to correct.
5. TIMING GEAR KNOCK: usually the most difficult to diagnose. If gear is loose or badly worn it will knock in all ranges. Run engine slightly above idle speed. Slowly open and close throttle. Knock will continue to be present, but just as engine slows down knock will become a slight rattle. Remove timing pin and reinsert into timing hole on timing gear cover. Press timing pin tightly against timing gear and accelerate slightly above idle. Knock will significantly be reduced or disappear. Correct by replacing both timing gear and crank gear as a matched set. The two gears should have a backlash clearance of .003 to .004. If more than .009 inch backlash, an oversize (.005) timing gear should be installed.
6. WRIST PIN SLAP: This can not be detected by shorting out the cylinder plugs. Rapidly accelerate and decelerate the engine speed. The engine will pass through a certain speed range when the wrist pin will rattle at about the same pitch as a valve tappet noise. This can be corrected by installing a new wrist pin bushing in the rod or new wrist pin f badly worn. Wrist pin should fit the piston and connecting rod with a tight metal to metal fit. The pin can be pushed into the piston and rod with a slight pressure of the hand. Pin to rod clearance is .0003 to .0005 inches.
if the noise is coming from the bottom end of the motor then you have either bad connecting rod bearings or bad crank bearings.if when you snap the throttle you hear a double knock then its connecting rod bearing if not then its crank bearing.a collapsed piston can sound low in the engine and its usually a dull knock noise.if you have the engine running and the noise is there and you pull off one plug wire at a time(and reconnect it after checking) and the noise goes away or mostly goes away with the wire unhooked then the cylinder that the noise changed is the cylinder that has a bad piston.
