I have everything hooked up correctly but for some reason im not getting any power to my sub in other words no sound brand new rca cables and i have the sub turned on from the headunit if you could help i would apprectiate it
Have you tried hooking up another amp to see if your sub comes on? i had the same problem, my wires inside popped off the speaker.
Have you got the auto ariel lead from the head unit connected to the remote connection on your amp?
if not then that is your problem, it turns the power on when you turn on the unit. and turns it off when you switch unit off.
hope this helps
