Hi there.
Try this It could do the trick for you.
The error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
I bet it happened when you first switched on one morning.
Easy to reset and fault usually goes away.
To Reset switch machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing.
Hope it did work for you.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
can not find switch under the front door
Bizhub 282 c3451 how can reset this code
thanks
SOURCE: Konika minolta bizhub 350 Error
error c3451 is abnormal heating temperature. al you have to do is reset the machine. open the back cover and on the main board look for a micro switch. press it will the machine is turn on. i hope this will help you.
SOURCE: HOW DO I SOLVE ERROR CODE C3451 IN KONIKA MINOLTA
You will need to replace the thermostat and the best solution is to ask a technician to do that.
