Recheck the way you have the motor leads hooked up, make sure they are correct. You did re connect the motor leads didnt you? You are not trying to run it on 230v single phase are you? Assuming it is a dual voltage motor, the leads will have to be re connected from hi voltage to lo voltage. Also when you cut the operating voltage in half the operating current(amps ) will double, all this info should be on the motor name plate. This motor does not use a capicitor to start it
Just checking but did you re-wire the motor for low voltage?
