I have bought a belkin 54g router, i have a sony Vaio laptop and i just cannot get it to connect. Ive tried EVERYTHING. I cant get onto the ip address and ive downloaded the manual....
help!!
I typed in my ip address & subnet mask and all i needed to do was choose
if it was an AR or UP but the button is disabled and i cant see whats wrong.
HELP !I typed in my ip address & subnet mask and all i needed to do was choose
HELP !
You can't post conmments that contain an email address.
If you access your router, look at the wireless settings, you may need to change a setting to allow b + g connections, your laptop may have a 'b' adapter.
If you connect the computer directly to the modem, does it work? If that works then the modem is working. Now connect the computer to the router and the modem to the router. You will need to open the set up page of the router to check the settings of the router. You can set up the router without the CD also. It is very easy. Click Here for step by step instructions about how to set up the router
Reset the router . CHeck if you can get a wired connection on your computer working . if it is not update the bios and the wired and wireless drivers. try reseating the wireless nic card as well .
Make sure that your router is set for an "encryption system" that is similar to all your computers and mobile devices. Example, if your router is set to encrypt using WAP2, make sure all your devices connect and is capable to connect using WAP2. Or else, set it to WAP and set your devices to WAP also.
This is more of an explanation then a solution, but to best explain what to do I have to first explain why this is happening. When you add security to a wireless router or ap you add extra envelopes to the packets of info being transferred, adding encryption to that makes it much slower because the ap has to encode all packets coming to you and un-encode all packets being sent to the Internet. In our time this happens very quickly, but in computer time I just described a lifetime. In addition if your signal is not 100% you might have packet loss "more slow down". Now the answer, in your ap setup pages you can setup wireless security, set this to Mac address authenication and add the mac addresses of all the network cards that have access to this ap. This is by far the fastest methiod of secure data transfer.
try resetting the router and the modem at the same time. then if that doesn't work try restarting your computer, like digi2112 said try upgrading you firmware
It is best to use the reset button on the router to start over. if it then connects you will have to reset all the passwords and setting you had previously.
HELP !
