Mitsubishi XD300U Multimedia Projector Logo
Anonymous Posted on Mar 14, 2010
Dear sir,I have mitsubishi xd300u projector.its working only in blac & white pls help me
Anonymous
Level 3:
  • Master 797 Answers
  • Posted on Mar 20, 2010
Anonymous
Master
Level 3:
Answers
797
Questions
Helped
191176
Points
2336
Sounds like the color wheel has failed. Can you hear the color wheel spin up when you start the projector?
Mitsubishi XD300U projector projects only black and white
How long have you owned the projector? Once I have all the information I can recommend the best solution please don't reject my solution until then as I know you will find me more then helpful.
Thanks,
Lee
1helpful
No color
Sounds like the color wheel is not working. Can you hear the color wheel spin up?
2answers
How can i see the lamp hours for mitsubishi xd300u ?
mitsubishi doesn't have a lamp timer that can be accessed. it will have an on screen message when it gets close, and it'll turn off when it is exceeded.
I have a Mitsubishi Multimedia Projector ( XD300U ) The fan is noisy and I am if I need to replace it. Is If so how do I remove it and where can I get a replacement part.
Open the case and check the color wheel for chips. Mine shattered and sounded like a broken fan. $+- 225 for new color wheel. Easy to replace and it worked fine.
2answers
"I believe your color wheel may have came apart. You should contactmitsubishi for an estimate. You can locate the nearest authorizeddealer here:
http://direct.where2getit.com/cwc/apps/w2gi.php?template=search&client=mitsuservicer#?mid=174138
Thanks,
Lee"
This is what i posted on your original post as well. This should be everything to get y ou going to know whether or not replacement or repair is needed.
If you need anything else let me know and if you have a moment to accept and rate my solution on your original problem I would greatly appreciate it.
Thanks,
Lee
Image flickers and colors off
I have the same problem as philvo. I was watching, the projector was operating normally, I heard a snap, there was a flash of light behind me I believe, and my Mitsubishi XD300U projector went to a black and white picture. That is all it will show now. All lights show normal operation. I would like to know if it is worth getting repaired. Does anyone have any ideas?
Top Mitsubishi Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
