Samsung TX-R2435 TV Logo
Anonymous Posted on Mar 04, 2010
Connecting headphones where do I plug in headphones? What else do I have to do?
Donnie Wayne Sharp
Level 2:
  • Expert 132 Answers
  • Posted on Mar 04, 2010
Donnie Wayne Sharp
Expert
Level 2:
Answers
132
Questions
0
Helped
26207
Points
400
I looked at the manual and I can't find any evidence that you have a headphone jack which is odd. I had 17" samsung and it had a headphone jack. The only thing I can think of is Wireless headphones. You could hook them up to your audio out rca jacks on your TV. I was just looking at a pair on amazon that had the right plug ins. But I don't want to say which ones because I don't want endorse a product when I don't know how well they work. They were reasonably priced. If this helps give me a vote please.
Testimonial: "Helpful, just no solution"
  • Donnie Wayne Sharp
    Donnie Wayne Sharp Mar 07, 2010
    You need headphones with plug ins like these.
2answers
I want to plug in my single input plug headphones into my vizio viz10
Some VIZIO TVs have a headphone jack built in. You can determine if your television has a built in headphone jack by looking in the user's manual in the specification section which is normally located towards the end of the manual.
tip
How do I Wire a USB Cable to a Stereo Phone Plug
<p>In general, the audio devices use audio cables such as RCA stereo headphones, or telephone cables, connection to other devices. In case you need a USB device to a stereo phone plug, you should use a single adapter cable to connect the USB cable will convert to a stereo phone. <br /> <p><br /> <p>1. Connect the USB end of the headphone adapter to the USB port of your audio device. <br /> <p><br /> <p>2. Connect one end of the headset to your male cable to the headphone port of the headset USB adapter. <br /> <p><br /> <p>3. Connect the other end of your headphone male to male cable to the headphone port of your stereo plug. Now you can connect to any port to connect to stereo. <br />
on Aug 05, 2011 • Cell Phones
1helpful
4answers
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
1helpful
Why do I only hear static
Hi Cathy.. it sounds like you might be connected to the wrong jacks instead of the output that the headphones need.
Most high quality stereo headphones have a single 1/4" stereo plug that would readily plug into a 1/4" jack on the front of the stereo labeled "PHONES" or HEADPHONES".
Many lower quality "computer headphones" or headsets have two 1/8" plugs. One is often black or red and is for an included microphone that may be a boom type (shown below) connected to one of the speakers or an "in-line" type built into the cord itself. The headphone speakers in the headset get their signal from the other plug - which is usually green; but could be any color really. There should be 3 metal parts on the stereo headphone plug. The tip, the middle ring and the bottom ring. Many times the mic is mono (not stereo) and only has only a tip and a bottom ring on the plug. You can see stereo headphone and microphone plugs he picture below:
Computer Headphones or "Headset" with mic and phone plugs.
Your Yamaha stereo will probably NOT have 1/8" jacks to directly plug the headphone into. You can buy an adapter that you would plug your headphones into and then plug the adapter into the 1/4" jack on the stereo. One is pictured below:
Front and rear views of a "1/4" to 1/8" Stereo Adapter Plug" The front plugs into the stereo and the the smaller 1/8" headphones plug into the rear.
I hope this helps & good luck!
1helpful
I WANT TO CONNECT HEADPHONES TO 1/4 INCH PHONE JACK ON TECHNICS AMPLIFIER IN A WAY THAT WILL CUT OFF SPEAKERS SO THAT AUDIO IS SOLELY THROUGH THE HEADPHONE. HOW DO I WIRE THIS USING THE PHONE JACK ON THE...
Please plug/ connect this wireless headphone base unit in Line Out jacks at back of amplifier to get sound in headphone and turn down amplifier volume control to shut off its speaker sound.
Thanks.
The left one has no audio.
If you have to pay someone to fix them, it would probably be cheaper to buy a new one.
You have little to lose trying to fix them yourself, but you will need at least a multimeter and a soldering iron.
The cable is what generally gets damaged often near the plug or the headphones.
See if you can find where the damage is.
One method is to open up the headphones and see if you have connections back to the plug from inside. Start with the one that is not working.
If you can't get a connection to the plug, go down the cable, looking for damage.
If you get to the plug, cut it off and strip the ends of the wires, and try to get a connection back to the headphones., and if so, fit a new plug.
Don't forget to put the wire trough the plug cover before you start soldering.
1helpful
4answers
Just bought the brookstone wireless tv headphones. I have a Westinghouse 40 inch lcd tv. I plugged in the rca red/white into the audio out and I don't get any sound into the headphones?
I had the same problem with Brookstone wireless headset the only solution I found was plug in the red and white connectors to your cable box it works perfectly that way. Just make sure the red cable connector from the transmitter is connected to right red input connector on the box. I have a Comcast cable box. Now I need a solution for them on my PS3?
I connect my Beyerdynamic DT131 wired headphone to my Sony Bravia TV through the cable box, audio volume is extremely low and the headphone's volume control had no effect on the volume. I tried connecting...
The audiolevel is much to low for a headphone.
You really need to use a headphoneoutput ( if its there) or a headphoneamplifier.
You tried to connect your headphone on line-level outputs.
Regards,
Gerard
Mic
If your headphones have a single plug you cannot plug these into a regular speaker connection or headphone connction and get mic and sound, you will need a headset that has 2 separate plugs (one for Mic and one for headphone) or a splitter you can get a radio shack. Most headsets have only one plug and there are connections for both the mic and the headphones on this plug, but the headphone connection on the computer has only connections for the headphone and therefore cannot detect the microphone.
1helpful
Bad connection
It sounds like you have two problems. One is your ipod earphone plug ( phono plug ) needs replacing, and # two is your headphone plug needs replacing.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
