Both of these indicate that there is a Problem with Pressure Switch.On Most of the Whirlpool Washer's ( Duet ), if you Open the top panel, then there would be 3 Screws. After that you would have an access to Pressure Switch.With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions. If the fault codes return after doing this, you will likely need to replace the pressure switch.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
This is good advice although the problem may also be a leak (not just a blockage) in the hose connected to the pressure sensor. In my unit the hose had been rubbing against something during the machine operation and eventually it wore through a section and left a pinhole. The first time I checked the hose I didn't see anything and confirmed there was no blockage. I was only when I put my finger on one end to block and breathed hard into the hose did I hear a whistling sound and figured it out. A little electrical taped fixed the problem although I will eventually replace it. Good luck.
