Delphi Roady XT XM Radio Receiver Logo
Posted on Mar 01, 2008
Great signal, so sound
Roady XT worked fine in my car today. Parked, took the receiver out and put it in my XM Boombox (NOT Belkin-- mine's white, "XM Audio System" boombox) and it didnt' work--perfect signal, but just a buzzing sound from the speakers. Took the receiver out of the boombox and put back into my car. Perfect signal, no sound. Tried to check "FM Frequency" but it's no longer a menu option--it just disappeared.
  • Anonymous Apr 03, 2008
    I took my roady xt out of it's cradle to change locations in my vehicle, after putting it back in the cradle I have signal and displat but it will not transmitt sound through my radio. All hook ups are verified correct. when I re-start and push menu to find FM Frequency, it does not come up. Any suggestions?
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jul 14, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
942
Points
8
There are problems with belkin boombox (white) and the rody receiver. the pins in the reciever get's screwed up when moving from system too system. i have both, but will not use my rody in boombox, i will use my express. lately i have had problems with my express so, we might be better off getting rid of the boombox.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 25, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
524
Points
My XM Boombox is also white and it is a Belkin. The folks at Delphi told me the receiver in the boombox is screwed up which over time also screws up the Delphi receiver. Belkin is sending me a new boombox and Delphi is sending me a new Roady XT.
Does not work when docked in boombox,not getting
the "reactivate" did not take in it's entirety, try calling sirus/XM again and see if they will "reboot it again, this time try having it the docking station within antenna "range", and both should "reboot", let me know if this fixes the problem, if not I have some friends there I can call, and we'll go from there, god bless and happy 4th......
Roady 2 signal goes in and out....
We've been having the same problem with our Roady XT unit at the office. Sometimes I think it's possessed because it goes in and out, changes to the mute mode, and sometimes turns itself off. Just got another Roady XT unit today. It played fine, then went into the mute mode. Called XM and they told me to reset unit to factory default. It's fine at the moment.
1helpful
Can't get Roady XT to turn on. Previously wouldn't load signal.
there is a bad connection on the voltage input on the radio. look in the hole you will see a copper contact if it wore, you will see a hole in it, you needed to bend it towards the center contact just a little bit. then try it again I worked on mine
3answers
Since Sirius took over, MY XM Roady will not stay on a station.
I called XM Radio and told them my problem. They told me to park my car in the drive way and turn on my XM Roady, an within the next three hours they would send a signal from the sattelite to fix the radio. Withing less than 30 minutes they had fixed it, and it works fine now.
XM and Sirius radios have merged and that is what caused the problem.
4answers
Xm radio
mine does the same thing.
6helpful
7answers
No FM Frequency option
I had the same problem with all three of my Roady XTs. I posted a video with directions for solving the problem on YouTube:
http://www.youtube.com/watch?v=BGMWf0aUTjw
Basically, you just need to have the antenna unplugged when you power up, and push menu right away, then select. Not sure why, but it worked on all of my Roady XTs. On the oldest one I had to push menu more than once. Good luck!
3answers
URGENT Belkin F5X007*****Please Read!!!******
same thing happened to me and I had to take the radio back to Walmart...
2answers
BelkBF5X007in XM radio boom box
Check your Conns both on Radio and docking Bay make sure Nothing Got on them .Clean them with alchol and Swab Good luck ttech
Roady XT periodic errors
The pins get easily damaged when switching from the car dock to the Belkin boom box. I have to constintly squeeze very ******* the top of the xt in order for it to make contact. Belkin will send you a plastic alignment fixture but it is too late. It still does the same thing.
1helpful
3answers
Delphi Roady XT Quit Working
Chances are it's not picking up the XM signal. First, contact XM to resend your setup. if that doesn't work check your antenna connections.
Top Delphi Audio Players & Recorders Experts
John
John
xxxxxx xxx
ExpressFiX
ExpressFiX
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
