Does anyone have a M-CODY M20 mp3 player. My PC wont recoginse mine via USB but happily charges from the same cable. I'm running vista so shouldn`t need any drivers. Can anyone help?
Try this. Turn your computer off. Plug in the mp3 via usb port with player in the on postion. Turn the computer back on. You should a large green battery symbol on the screen flashing left to right. Took me about 3 days of finally fiqure it out. Also try different USB ports if you have more than one. Good Luck
assuming you want to access through the player, you may be able to switch storage devices in the settings, connect the unit to a pc via usb and search in my computer in the folder on your player or remove and place in a card reader connected to a pc.
The best cable to use is the one that came with the player If that does not work, try a different cable. It may be faulty. Any cable that plugs in may not work, some usb cables are made for charging only, you need a charging/data cable.
The player needs to be charged via the USB connnection on your PC. If it doesnt fit, try the USB ports on the back. If its not working/not charging, please test the MP3 player on another PC.
I'm sure it's the cable that's not functioning properly. Mine started doing the same thing and after wiggling and adjusting the cable inside the MP3 itself, the computer finally recognized it and I was free to charge and add music. Also you can try to connect it to a different USB port on your computer. The beeps however are news to me, unless I just never noticed. One piece of advice is to never let the MP3 battery die, because after I let it happen mine began to experience more severe problems.
it does not seems to charge / or turn ON either from the computer or when plugged to an electrical outlet to the wall. Red light is still ON after the whole night . What's wrong ?? Can you please HELP - CODY STELLER MINE IS A 4 GIGA BITE MP4 PLEASE HELP ONLY
the player has to be connected to computer via USB cord one end goes into the mp3 or mp4 and the other goes into the usb port after it has charged to turn it on u have to hold the menu button down/ Thats how mine work Does anyone know how to add videos I have added pictures which looks beautiful.
Are you sure it's not charging? What makes you think it's not charging? When you plug the USB cord in (and it's attached to the charger or the PC)a screen should appear temporarily. It shows a picture of a PC with a usb cable coming out of it. Are you not even seeing that much?
Remember that this is a no-name Chinese player, so don't expect iPod or iRiver quality.
I didn't think mine turned on, but that's because the on/off switch was sticky and because you need to press play once or twice after it's turned on to get it to do anything. But so far, mine's working fine.
