20 Most Recent Coby MP-610 MP3 Player Questions & Answers
Check the specification of your MP3 player to determine thetype of video file format it uses. Most common video files that MP3 players use are, AVI andWMV, there may be others such as FLV, MOV and DivX. If your player cannot play a video then it is anincompatible video file format, then you need to convert that video file to aformat that your MP3 player uses. Click on this link for instructions on converting videofiles for MP3 players :- http://www.fixya.com/support/r5874192-play_videos_mp3_player
Coby MP-610 MP3... | Answered on Apr 16, 2019
have it at rapidshare.......... i have uploaded the coby manager.exe file......
Coby MP-610 MP3... | Answered on Jun 23, 2018
Coby Media Manager download can be acquired on the support site:
http://www.cobyusa.com/?p=fix_mp822
Download the install wizard "coby-mediamanager-2009b0924.exe":
http://www.digdash.biz/product/coby/coby_media_manager/install/coby-mediamanager-2009b0924.exe
(After installing the wizard you can change your language if needed
under Tools > Options... and select your User Interface Language)
Listing for all supported players in Coby Media Manager
Coby MP-610 MP3... | Answered on Sep 09, 2017
Hello.
Try to adjust the headphone.
Check if it is connected properly.
If it still doesn't work, try to check the headphone on other devices.
If the headphone is working on other devices, your MP3 headphone jack has some problem.
But if the headphone is not working on other devices, you should get new headphone or you can try other headphone (besides your current one) on your MP3.
hope it helps.
Coby MP-610 MP3... | Answered on Dec 12, 2016
1. You can get the Coby Media Manager here:
CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
2. You can get a PDF Manual here:
http://www.cobyusa.com/?p=doc
or click on one below:
Available Downloads for MP610
Downloads for MP610 1.8" Video MP3 Player
Coby MP-610 MP3... | Answered on Jul 03, 2015
Tip
COBY 610 File System Error
Fix the File System Error of Your
COBY 610
Replacing the firmware of your Coby 610 MP3 Player will unfreeze it and help it act normally again. This will also fix the 'File System Error' that has been popping up with some Coby 610 players. You can find it at the cobyusa.com website by choosing 'Mp3 & Portable', then 'Mp3 & Mp4 Players', then your model 'MP610', from the support page. Or, here is the direct link to the file from Coby's servers.
Unpacking the zipfile from the Coby Website will give you a pdf file with instructions, and a program file to run.
Your music will be erased when you run this firmware update. The instructions suggest that even if your mp3 player won't startup properly, if you plug it into your computer you should be able to access it as a removable disk, and copy all your music to a temporary folder on your computer.
Here are the steps:
  1. Plug your MP610 into your computer.
  2. Copy all your music to a temporary folder.
  3. Disconnect your MP610 from your computer.
  4. Disconnect as many USB devices as possible from your computer (to simplify identifying the MP610 at a later step, and avoid damaging other devices by trying to load the MP610 firmware into them by mistake.)
  5. Run the Firmware Update program 'MP610 T LCD Firmware Update for file sys err.exe'
  6. You will see a screen with up to 24 numbered, empty boxes.
  7. Connect the MP610 to your computer. It will show up in one of the boxes.
  8. Once the MP3 player shows up, click on the Firmware Feature icon to start the firmware upgrade.
  9. After the firmware update is complete, you will receive a checkmark in the firmware box.
  10. Disconnect the MP610.
  11. Close the firmware update software.
  12. Turn on the 610 to confirm it starts up and the display reads 'COBY'.
  13. Plug it back into your computer and copy your music back on to it.
on Feb 14, 2014 | Coby MP-610 MP3 Player
Most basic MP3 devices such as this one, simply mount on your desktop like a flash/USB stick drive when you plug it in. If it does mount, just drag your audio files into the appropriate folder on the mounted drive to transfer your music.
Coby MP-610 MP3... | Answered on Jan 06, 2014
Coby MP-610  MP3 Player Logo
631 questions posted
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Joe Negus
Joe Negus
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Coby Audio Players & Recorders
Most Popular Question
create
  • Audio Players & Recorders
