If the trouble with the gauge started after you worked on it then you likely damaged or created a restriction to the movement of the sending unit. You will have to remove the tank and double-check your work.
Float is off. Just try to put a full tank of gas in it and watch the gauge. Noone can siphone your tank BC there is a ball before the tank abling u not to siphoned.
The fuel sender is in the tank and is part of the fuel pump module ( all in one). the fuel sender is a rheostat and is like a dimmer switch in you home to dim lights, the higher the level of fuel the more voltage the computer sees hence the lower the fuel the lower the voltage it sees. With the age of the car this is likely the problem. But there is a part in the instrument cluster that reads this voltage and sends power to the gauge intermittently. In older cars it was called a anti slosh module. It was there because as the car went up and down a bumpy road the gauge would read erratically.
the cost can be prohibitive to fix this but if you can live with it i would. If not expect to spend 600 dollars or more to trace it down and fix it.
Hello. You may have a problem with the fuel sending mechanism in your gas tank or you may have a fungus in your gas tank which is causing it to show much more fuel than you actually have. Drive to an AAMCO repair shop where they will scan your car's computer for free [some auto parts stores now offer this free as well so call around]. If it is mechanical it should show up on the scan, if not you probably have the gas fungus. Some auto parts stores and dealerships now sell an expensive gas tank additive that will kill that fungus. Regards, Joe
