Pls make sure that you loaded the paper correctly.
Open the paper support and pull up the extensions.
Open the output tray and pull out the extensions. Then flip up the paper stopper on the last extension, unless you’re printing on legal-size paper.
Flip the feeder guard up, out of the way, then squeeze the edge guide and slide it left.
Insert paper, printable side up, against the right side and beneath the tab.
Load paper short edge first, no matter which way your document faces.
Load letterhead or pre-printed paper top edge first.
Do not load paper with holes punched in it.
Do not load transparencies.
Do not load paper above the arrow on the edge guide.
Check the paper package for any additional loading instructions.
5.
Slide the edge guide to the edge of the paper, but not too tightly.
if you put the paper correctly and still not feeding the paper correctly, that means the rollers of the printer is broken
pls make sure that you loaded the paper correctly.
5.
5.
5.
