Adaptec (2120S) SCSI Controller Logo
Posted on Feb 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SCSI BIOS not installed / ML150G2, exchanged mainboard, RAID
I have an HP ML150G2 server and the mainboard got defected after a year. I got a new mainboard, but the problem seems to be that I had RAID 1 on the old mainboard - with the adaptec 2120S SCSI controller - so the RAID configuration is not found on the new mainboard, so now if I boot up with the old 2 hard disks, I get "SCSI BIOS not installed" and then "No operating system found". The hard disks are still functional, because I have an identical server and they boot normally in that server.
Can I add the BIOS/RAID configuration without formatting the hard disks?
Or can I rebuild the SCSI BIOS from the hard disks?
there are 2 menus for the scsi adapter, both accessible with Ctrl-A. the 2nd one shows something like this:
Manage Arrays
Create Array
Initialize..
Rescan Drives
But none recognizes the hard drives. Although they are recognized while booting.
Thanks
  • 1 more comment
  • airjaws Feb 23, 2008
    thanks. i already tried hp's and adaptec's websites. i didn't find a solution. as for live chat at hp, it is possible for products like printers, but not servers.
    thx. i tried hp's and adaptec's websites and found no solution. as for the live chat at hp, it's only for products like printers, but not servers.
  • Almak Sep 02, 2008
Anonymous
Level 2:
Scholar:
  • Expert 121 Answers
  • Posted on Feb 23, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
121
Questions
0
Helped
27457
Points
280
Hi..
my guess is no but since i haven't dealt with this type of server i'm going to suggest you go to hp.
if you just goto hp.com and search on live chat and a link will come up.. they should be able to help unless it's too old since i'm not sure what generation we are on now..
good luck, hope this helps a little..d
  • Anonymous Feb 26, 2008
    mmmm... that's interesting bc my partner is an account manager there and she only sells high end servers and that's what she uses.. i'll have to ask her about that, maybe there is a different site.. thanks, d
How to installed xp2 in server hp proliant ml 350 my hard drive ok
You may need raid controller driver for HP proliant ml 350. Copy raid controller driver in flopy disc, insert it in flopy drive, insert cd in cd driver, boot server from cd and start installation process, as soon as you see Press F6 if you need to install third party scsi drivers or raid controller, press F6 and follow the instruction. It will then ask you to select RAID driver file and then will continue to windows xp installation.
Regards,
Kaushik Patel
2answers
Proliant does not boot from raid controller if external SCSI drive is powered on.
Try to disable boot to other device on your bios setting.
Make sure that your Smart Raid is set on the first boot device.
I have ML350 G3 Server SA 532 and 2 HDD SCSI, W2K. I want intall RAID 1 Can I help me???
unable to understand your question.
If you want to configure raid 1 and install OS freshly then follow these steps.
1) make ready all the required h/w.
2) Swith on the server.
3) when post starts reading SA532 controller press F8 button .
4) you will enter into Raid card bios.
5) select View to know any existing logical drive.
6) select Create logical drive,select both hdd's by pressing space bar.
7) press F8 to confirm changes,save and exit.
8) Enter into bios and set the boot controller order smart array controller as 1st.
9) press escape button and restart the server.
10) boot with cdrom and proceed for os installation.
6)
1helpful
2answers
Unable to boot to anything external.
Save yourself some trouble. Pull a CD/DVD drive out of another computer or just buy one. They are very cheap. Connect the CD/DVD drive to the server and install the OS as usual.
If you are lucky WS2008 will already have a compatible SCSI/RAID driver. Otherwise, you will need to press F6 and install the driver from the floppy.
If this helps please vote for my solution.
2helpful
2answers
Boot problem with IBM xseries 206 - SCSI Drive and SATA drive
Refer to user's manual how to set the boot order in BIOS.
Prolinat ML350 G2 WONT BOOT UP
You have apparently attempted to attach a tape drive or other similar device to a SCSI RAID controller. You will need to get a separate SE SCSI HBA instead. These are pretty cheap, usually just over $100 list from HP.
If you haven't attached anything new, then you should check your cables first and if that doesn't help I would suspect a bad RAID controller.
Pci ide controller for third hard disk
You need to enter into scsi bios first, then do an autodetect for hard drive, this will set the IDE/SCSI hard drive on raid controller.
To enter SCSI control you need to press the same key stated on screen on startup (F6 I assume) I think F3 is just boot settings.
If the card do not enter regularly in CMOS settings for the raid then this card is defective.
3answers
3helpful
3answers
Install windows xp pro
Hi
My is working , i have same dell server 1600 , i download the driver from LSI website here is the link
http://lsi.com/storage_home/products_home/host_bus_adapters/scsi_hbas/lsiu320/index.html?remote=1&locale=EN
you just need u320 scsi driver for server 1600sc
download XP driver 32 bit it will work
victor
3answers
I want to format scsi drives and configure raid0
You can either do this in the BIOS or (easier) just run a Linux installer (such as Ubuntu) and it will offer to do it for you when it sees Windows-formatted partitions.
Top Adaptec Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Adaptec Computer and Internet Expert? Answer questions, earn points and help others
