20 Most Recent
HP Compaq ProLiant ML350 G3 Server Questions & Answers
Internal led of ML350 server is glowing
Hi Franceso, plz specify
Is it powering ON ?
Which LED is glowing?
These leds are there on the front panel :
1 Power On/Standby button
2 System power LED
Green = Power on
Amber = System shut down, but power still applied
Off = No power
3 Internal health LED (Wave sign in BOX)
Green = Normal
Amber = System degraded. To identify the component in a degraded state, refer to system board LEDs.
Red = System critical. To identify the component in a critical state, refer to system board LEDs.
Off = Normal (when in standby mode)
4 External health LED (power supply)
Green = Normal
Amber = Power redundancy failure
Red = Critical power supply failure
5 NIC 1 activity LED Green = Network link
Flashing = Network link and activity
Off = No link to network.
6 UID LED Blue = Activated
Flashing = System remotely managed
Off = Deactivated
7 UID button
If it is Internal health led then any internal h/w issue is suspected.
If it is external health led then any power supply or power source related issue is suspected.
Also
check the status of the server & its IML (Integrated Management
Logs) in ilo (Integrated Lights Out ) if it is configured. (2nd RJ45
port in rear)
Also make sure the cabinet is properly closed.
3/6/2018 1:24:22 PM •
HP Compaq...
Answered
on Mar 06, 2018
No display when powering on
This happens allot when the Operating system has had an update, have you tried clearing the cmos , to load the operating system and disable the other driver , i have noticed that within the Computer Management Table that if you click on Device Management, then click on Display Adapters, their is sometimes two, if your resolution is set higher than that of the other driver that is not capable of such resolutions, then you get exactly what your describing , to solve this , clear the c-mos and, it will use the default to load the system, remeber to disable the other before you restart the machine , i know this is an issue but it may not exactley be the issue you have but its a Start , please let me know if you have any other issues
5/11/2014 10:59:41 PM •
HP Compaq...
Answered
on May 11, 2014
Server no display when power on
Can you confirm that server fan is rotating or not when server power on. and which led glowing red when you power on server
5/5/2014 4:17:16 AM •
HP Compaq...
Answered
on May 05, 2014
Problem with harddrive
It could be because the disk is not a part of any array. Log into the server and go to the array controller utility from HP and check for any unassigned disks. It will be displayed there rather than the diskmanagement window.
4/13/2014 7:45:34 AM •
HP Compaq...
Answered
on Apr 13, 2014
I have a proliant ml350
Put RAM's in Identical form and check.clear NVRAM and Check.check the array controller update BIOS and Array controller firmware ( disconnect HDD's from the cage before updating the latest Firmware( download from hp.com/support and drivers )
11/20/2013 10:22:04 PM •
HP Compaq...
Answered
on Nov 20, 2013
Hdbd
explain problem clearly
10/25/2013 1:56:07 PM •
HP Compaq...
Answered
on Oct 25, 2013
