Emerson EWR20V4 DVD Recorder/VCR Logo
Posted on Feb 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It will not load certain dvd discs - Emerson EWR20V4 DVD Recorder/VCR
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 2 Answers
  • Posted on Aug 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
1959
Points
7
Below is a list of discs that should or should not be used with the DVD recorders.
DVD-R
4x can be used
8x will result in a disc error.
DVD-RW
2x can be used
4x will result in a disc error.
The following discs have been tested and are proven to be compatible with our DVD recorders.
MEMOREX DVD-R
FUJIFILM DVD-R
FUJIFILM DVD-RW
IMATION DVD-RW
IMATION DVD-R 2.0
TDK DVD-RW 2X
TDK DVD-R 2X
The following are brands of discs we DO NOT recommend:
MEMOREX DVD-RW
SONY DVD-RW
SONY DVD-R
TDK DVD-RW 4x
TDK DVD-R 4x
Please be aware that a free software upgrade is now available to customers. This upgrade will enable your unit to recognize the (DVD-R 8x) discs. To obtain a copy, please call 1-800-242-7158. Customer service by phone is available 7 days a week 6:00am to 9:00pm pacific time.
In order to receive the upgrade we need to know what firmware version your unit requires. First you need to access the DVD recorders service mode. Turn on the DVD Recorder and the Television, make sure the unit is on the DVD side. You may access the service mode by pressing the CMSKIP button on the remote control. Once you press CMSKIP you must press the numbers 1,2,3. You must do this quickly so it may take a couple tries. The model name will appear on the screen followed by Firmware Version. I need to know the serial number next to FE:
Press the RETURN button to exit screen.
Brian W.
Customer Support
Funai Corporation
19900 Van Ness Avenue
Torrance, CA 90501
1-800-256-2487 Customer Support
1-310-320-0571 fax
Anonymous
Level 1:
Problem Solver:
  • Contributor 1 Answer
  • Posted on Aug 04, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
5
Helped
1537
Points
I am confused, it will not load the DVD-R, what dvds will it take?
Paul Hutchinson
Level 3:
  • Master 909 Answers
  • Posted on Feb 07, 2010
Paul Hutchinson
Master
Level 3:
Answers
909
Questions
0
Helped
273397
Points
2687
You may find the disc that are not loading need to be finalised or closed by the pc or dvd recorder that made them. (assuming recorded discs) or even that they are dvd+ and your player won't play dvd+(dvd- being the format for most origional dvds)
Why does the disc reader say "no disc" after I put one in? It played earlier
Not all disc are equal.
Try a different disc. Some machines can be fussy about certain discs. Sometimes the disc itself can be kerfluewy, so try the disc in a different machine, too.
2answers
Magnavox tv combo
Did you try disconnecting the unit from the power for a few hours?
Shows no disk when there is a disk. how do I fix it?
Simply, some DVD players just will not play certain discs. Especially copies of discs. If your having trouble with a movie that is made for release, ya know, one you buy at a store.....then make sure the disc is clean, no scratches, and loaded correctly. Also, maybe buy a disc cleaner disc for cd/dvd players. Lastly, remove any discs, turn off the dvd player, unplug it for a minute, plug it back in, turn on and load a disc. Hope this helps.
When loading time occurs it does not read the cd
They say these things are sent to try us and a dvd that will npt play a disc certainly dose that, but if we can understand the nature of the beast we can get the better of it. The first thing after loading is for the dvd to recognise the disc and it dose this by first finding focus. It dose this several times before giving up. If it finds focus it will then rotate the disc and read the TOC (table of contents). It would seem that your dvd cannot find focus. Most likley cause is a dirty laser lens. Cleaning the lens with a cotton bud will in
most cases effect a cure. If not a low emission laser may be the culprit. When cleaning the optic lens take extreem care the lens mountings are easily damaged. If lens cleaning dose not solve your problems it would be wise to seek advice from your local service technician.
1helpful
Screen says loading.Then says (no disc)
There are a lot of reasons why that could happen. Sometimes when a DVD player needs to be cleaned it won't read a disk.Sometimes when you try to play a NTSC disk on a PAL DVD player or visa versa it won't play. Region coding could be another issue. And sometime home burned DVDs won't play in certain players.
2helpful
2answers
Will not read dvd disc
This can be due to dust in the machine, on the disc or surdace damage to the disc.
These are the most common causes anyway.
Clean the disc itself with plain water and wipe with a soft cloth gently to dry it.
Run a CD Cleaner disc in the machine for 30 seconds, and dust off the loading tray/area with a soft brush.
Then try again.
Try other discs to see if the machine is ok - or whether it is the new disc that is faulty.
Smetimes you have to load the disc 3 or more times untill it reads a certain bit of data correctly to start, after this it doesn't seem so important.
2answers
The recorder reads no disc or load once loaded
try to use a CD lens cleaner, it still won't read, you need to have it serviced.
DVP3140 - will not recognize disc
all players will not play certain disc's I.E. DVD+r or DVD -r , check to see what disc your using and try another original disc. Clean the glass eye near the spindle, use 90 % alcohol with swab,gently. Please rate.
"No Disc"
"No Disc" also means "I can't read the Disc". The laser must be able to read the disc or you'll get that. There are several reasons:
Bad or noncompatible Disc: Some units won't play certain types of recorded discs. Try a rental or bought DVD.
Dirty laser lens: Either try a cleaning disc, or GENTLY clean the lens with a moistened Q-Tip.
Defective components like laser, spin motor, tracking motor, etc. Usually requires professional servicing.
Hope that helps...
Geno
I can't get my dvd to load
Do you get this error with every disc, or with a specific one? could it be possible that the discs in question have certain features on them that can't be used with your player? such as audio tracks,subs, angles etc? If you're burning discs, always do so in 2x or 4x, turn off all other programs while ripping/burning. Try other discs and post back if you have any more info
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
