I need to record my own voice files using olympus dictation machiine then put these onto a cd which I can then post out to clients. What software do I need please?
If you are already using your dictation machine then you don't need to install its software as its already installed. Now you only require Nero for burning files to CDs. You also require a CD writer installed on your pc. You shall know where your files are saved when you record through dictation machine. If you can't find the recorded files kindly comment back.
Testimonial: "thank you for your advice. I am using a portable dictation machine does this make any difference? I was expecing to be able to plug in by USB "
Well since you have not used your dictation machine with your pc then now you are required to just plug it in through usb and install the driver when asked by the pc through the CD which you received alongwith the machine. Since I don't know your machine's model i can't provide you with download link.
