Coffee Makers & Espresso Machines Logo
Posted on Feb 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E040 motor timeout - Franke Evolution
Anonymous
Level 2:
New Friend:
  • Expert 92 Answers
  • Posted on Jan 11, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
92
Questions
0
Helped
50587
Points
244
Check the brew piston micro switch for damages or loose wire connections, If this doesn't help you have to run a test and for this you need the "install card" and a volt meter
CANON imageFORMULA DR-X10C II ERROR "E038"
The Service Manual only mentions the Platen Motors, but follow the connections back to the control board and clean them with switch cleaner. Also look for any sensors that use the platen motors for functional logic decisions.
Canon imageFORMULA DR-X10C Service Manual page 164
ManualsLib https://www.manualslib.com > ... > Service manual
View and Download Canon ImageFORMULA DR-X10C service manual online. ... E038. Platen motor. E040. Control PCB Sub-CPU communication failure.
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Service code interrupt
Error type T11 [Pressure-control motor lock]
T11-***
!!System Error!!
Press Reset Key
If Recovery has Failed, Call Service
Reset method Jam reset or switch on power again
Error point Error conditions
600
Timeout error for reducing pressure (OFF -> ON) during print-pressure home
positioning.
601
Timeout error for increasing pressure (ON -> OFF) during print-pressure home
positioning.
602 The print-pressure limit sensor does not change during print-pressure operation.
620 Print-pressure operation was called with the print-pressure motor locked.
621
Incorrect print-pressure operation timing (print-pressure operation command was
received when the print-pressure should not change).
622 Sensor A is ON and sensor B is OFF during movement from area A to area D.
623 Either sensor A or sensor B is ON during movement from area D to area A.
624 The current area data is undefined.
625 The target area data is undefined.
626 Timeout during relative print-pressure movement.
Error type T12 [Master-disposal-section motor lock]
T12-***
!!System Error!!
Press Reset Key
305
The master compression sensor does not go ON within 6.5 s after the master
compression motor operates in the return direction.
306
Master compression sensor does not go OFF within 2 s after the master
compression motor operates in the compress direction.
307
compression motor operates in the compress direction, and the mastercompression-
motor limit sensor cannot count up until the compression-limit
position.
309
The master-compression-motor limit sensor does not change within 200 ms
during compression operation.
hope to be of help
1helpful
Timeout treadmill fault
1) lube the deck belt
2) lube the rollers bearings
3) measure the input voltage motor, if there are the motor need repair
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
SEE The block.
God bless you
E044 motor timeout coffee machine
E044 motor timeout coffee machine on bewleys coffee machine . How do I reslove this . I cant make coffee
Sc335 ricoh 2045 copier
  • Code: 335
  • Description:Polygonal Mirror Motor Error 1: ON Timeout
    The XSCRDY signal is not issued (LOW: Active) within 25 s after the polygonal mirror motor switches on.
  • Causes:• I/F harness of the polygonal mirror motor disconnected or defective. • Polygonal mirror motor or polygonal mirror motor driver defective. • Polygonal mirror motor drive pulse is not output incorrectly. • GABIC cannot monitor XSCRDY signal.
1helpful
2answers
Duplicate/incorrect MAC addresses in the CAM table
This is from the Cajun P333R manual but it should be very similar if not identical.
Good Luck.
arp timeout Command
Use the arp timeout command to configure the amount of time that an entry
remains in the ARP cache. To restore the default value, 14400, use the no form of
this command.
The syntax for this command is: arp timeout <seconds>
The syntax for the no form of this command is: no arp timeout <seconds>
Examples:
To set the arp timeout to one hour:
Router(configure)# arp timeout 3600
To restore the default arp timeout:
Router(configure)# no arp timeout
ip-address IP address, in dotted decimal format, of the station
hardware-address 48-bit address of the local data link
seconds The amount of time, in seconds, that an entry
remains in the arp cache.
Top Franke Coffee Makers & Espresso Machines Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
john h
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
