Computers & Internet Logo
Posted on Feb 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I SHOW A MESSAGE INDICATING ERROR 04095. wHAT IS IT. hOW CAN I REPAIR IT My machine is a CR Konica Minolta Regius Model 190
dj_relly999
Level 2:
President:
  • Expert 4,070 Answers
  • Posted on Feb 10, 2010
dj_relly999
Expert
Level 2:
President:
Answers
4070
Questions
0
Helped
1065909
Points
207
Good day, just for a try maybe you can unplug the machine then turn on the power while unplugged for 10secs. then plug the machine and turn it on and see if something happens. if theres no luck maybe you can call a konica technician. hope this helps, have a nice day
How to Solve C 3502 error code in konica Minolta c 6100 1100 1085 6085
The C 3502 error code in Konica Minolta c 6100, 1100, 1085, and 6085 machines is related to the fusing unit. The error code indicates that the fusing unit is not heating up correctly. There are several reasons why this error code might appear, including a malfunctioning thermistor, a broken fuser heater lamp, or a damaged fuser thermostat .
A video: how to solve C 3501 3502 3503 3504 3505 3506 error in konica minolta 6500 6501 6000 7000 - YouTube
Turn off the machine and unplug it from the power source.
Remove the fusing unit from the machine.
Check the thermistor and fuser heater lamp for any damage.
Replace the damaged parts if necessary.
Reinstall the fusing unit and turn on the machine.
If the error code persists, it is recommended to contact a Konica Minolta service representative for further assistance
I HAVE A KONICA MINOLTA 190F COPIER PLS DIRECT ME ON HOW TO COUPLE THE DRUM ITSELF TO THE HOLDER
Please refer to the service manuals and this.
Replacing a Drum Unit
Konica Minolta Manuals
https://manuals.konicaminolta.eu > contents
After Drum Unit replacement step 1 has been completed, check that the red-circled lock is located at the position indicated by a dashed line, then execute step ...
Konica Minolta REGIUS 190 Service Manual
ManualsLib
https://www.manualslib.com > ... > REGIUS 190
View and Download Konica Minolta REGIUS 190 service manual online. REGIUS 190 medical equipment pdf manual download. Also for: Dd-941.
Konica Minolta - Regius 190 Community, Manuals and ...
MedWrench
https://www.medwrench.com > equipment > konica-m...
Konica Minolta - Regius 190 by Konica Minolta. Konica Minolta - Regius 190. Forums ... Regius 190 Service Manual. SERVICE COMPANIESView All Computed Radiography ...
Konica Minolta Regius 190 (DD 941) Service Manual
Internet Archive
https://archive.org > details > manual_Konica_Minolta...
May 20, 2020 - KONICA MINOLTA. DIRECT DIGITIZER. REGIUS MODEL 190. (DD-941). SERVICE MANUAL. KONICA MINOLTA MEDICAL & GRAPHIC, INC.
..https://www.youtube.com/watch?v=lqfANSFl6Io
Konica Minolta Magicolor II
WOW. now that is a LEGACY Minolta Machine, Konica Minolta web site does not even list that machine try this site for a service manual
Service manuals electronic components datasheets and equipment schematics...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
I have a Konica Copier. Showing error message P81
sure it a model #2223T what does it say on the sticker on the back of the machine number you gave is nothing!!!
My printer Konica Minolta stopped working and showed me an error code F-26-6
The printer stops working & showed me an error code F-26-1
www.fixya.com/.../t16683015-printer_stops_working_amp_showed_me
Feb 20, 2013 - the printer stops working & showed me an error code F-26-1 , How can I repair it ? I think it s relating to a - Konica Minolta 26NA53040 7130 ...
Konica Minolta 26NA53040... Repair Questions - Fixya
www.fixya.com/.../p4700437-konica_minolta_26na53040_7130_7025_...
Konica Minolta 26NA53040 7130 7025 7020 Oem Lower Fixing Roller Assy New ... Theprinter stops working & showed me an error code F-26-1 , How can I ...
1helpful
Hiya, When I turn my camera on it says it has a 'system error' and then turns itself off. Any ideas what I can do? Thanks Its a Konica Minolta DiMage
Hello
Unfortunately a "system error" message is not something that you will be able to fix. This error indicates a system failure and requires the camera to be sent in for servicing and repair.
However, since Minolta is out of business, you may be hard pressed to actually get this camera repaired.
56helpful
5answers
How do I clear error message C-2558 for the Konica Minolta bizhub C253
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Top QPS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a QPS Computer and Internet Expert? Answer questions, earn points and help others
